Martini 914 1974, restoration thread |
falcor75 |
Feb 2 2013, 09:09 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Got my first 914 home last monday...barely had time to look at it becuase of work.... was in rougher shape than the pictures I was sent of it before buying it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.964c2.se-15176-1359817741.1.jpg) Spec's: Front glasfibre hood Rear glasfibre hood Front GF bumper (cracked) Rear GF bumper Rollcage Old five point harnesses, will be discarded. Three point belts will be installed (needed to pass Swedish registration) Rebound adjustable red Koni's front and rear Springs "140 lb Weltmeister" Engine overhauled 2001: "Euro" pistons Camshaft, unknown spec. Overhauled heads with new valves and guides Weltmeister oiltrap Flywheel lightened 2 kg's Frontmount oilcoover External oilfilter etc.... It's a pretty rough looking car but the plan is to get it registered (ex California car, I got it from 914er-teile in Germany) and then tear it to pieces and do it right, find all rust, fix it and have it resprayed. Yes, my projects tend to go overboard.... (IMG:style_emoticons/default/biggrin.gif) The long term plan is to build my own version of a "914 RS" in the same kind of way as the 964 RS was made. Original looks, a little bit lighter, a little more power, a little better brakes and handling. |
falcor75 |
Feb 3 2013, 06:33 AM
Finished the seatbeltinstallation today and cleaned up the rear vinyl pad aswell since it was quite nasty. Did some looking around and this is what I've found to fix so far.
* Brake lights doesn't work.... *High beams doesn't work, no click from the relay when I pull on the stalk *Washer bottle non existant, will convert to electric pump system. *Interior light broken *Instrument lights very weak, probably a few dead bulbs *Need both rear rubber grommets that hold the top in the trunk *Left rear wheel hard to turn, probably stuck hand brake... more to come as I find it... (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 04:27 AM |
