Martini 914 1974, restoration thread |
falcor75 |
Feb 2 2013, 09:09 AM
Senior Member Group: Members Posts: 1,578 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Got my first 914 home last monday...barely had time to look at it becuase of work.... was in rougher shape than the pictures I was sent of it before buying it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.964c2.se-15176-1359817741.1.jpg) Spec's: Front glasfibre hood Rear glasfibre hood Front GF bumper (cracked) Rear GF bumper Rollcage Old five point harnesses, will be discarded. Three point belts will be installed (needed to pass Swedish registration) Rebound adjustable red Koni's front and rear Springs "140 lb Weltmeister" Engine overhauled 2001: "Euro" pistons Camshaft, unknown spec. Overhauled heads with new valves and guides Weltmeister oiltrap Flywheel lightened 2 kg's Frontmount oilcoover External oilfilter etc.... It's a pretty rough looking car but the plan is to get it registered (ex California car, I got it from 914er-teile in Germany) and then tear it to pieces and do it right, find all rust, fix it and have it resprayed. Yes, my projects tend to go overboard.... (IMG:style_emoticons/default/biggrin.gif) The long term plan is to build my own version of a "914 RS" in the same kind of way as the 964 RS was made. Original looks, a little bit lighter, a little more power, a little better brakes and handling. |
falcor75 |
Mar 3 2013, 02:32 PM
Ok, I need to be educated on the warmup and idle behaviour of a Djet 2.0
Mine starts up easily with a little throttle help the first few seconds when cold. Idles around 1000-1200 and after half a minute or so the idle raises to about 2500-3000 and stays there, after 5-10 minutes it slowly decreses down to around 1500. From what I've read the rising idle untill warm is normal but a but too high. I couldn't find any vacuum leaks with starterfluid but need to try it again since I only had a few squirts left in the can. |
Lo-Fi Version | Time is now: 28th March 2024 - 07:37 AM |
