Martini 914 1974, restoration thread |
falcor75 |
Feb 2 2013, 09:09 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Got my first 914 home last monday...barely had time to look at it becuase of work.... was in rougher shape than the pictures I was sent of it before buying it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.964c2.se-15176-1359817741.1.jpg) Spec's: Front glasfibre hood Rear glasfibre hood Front GF bumper (cracked) Rear GF bumper Rollcage Old five point harnesses, will be discarded. Three point belts will be installed (needed to pass Swedish registration) Rebound adjustable red Koni's front and rear Springs "140 lb Weltmeister" Engine overhauled 2001: "Euro" pistons Camshaft, unknown spec. Overhauled heads with new valves and guides Weltmeister oiltrap Flywheel lightened 2 kg's Frontmount oilcoover External oilfilter etc.... It's a pretty rough looking car but the plan is to get it registered (ex California car, I got it from 914er-teile in Germany) and then tear it to pieces and do it right, find all rust, fix it and have it resprayed. Yes, my projects tend to go overboard.... (IMG:style_emoticons/default/biggrin.gif) The long term plan is to build my own version of a "914 RS" in the same kind of way as the 964 RS was made. Original looks, a little bit lighter, a little more power, a little better brakes and handling. |
falcor75 |
Nov 10 2014, 01:22 PM
This weekend was 2 steps forwards and then 1½ backwards... (IMG:style_emoticons/default/headbang.gif)
Glued the races for the front A-arm bushings on the A-arms on friday in preparation for mounting the front suspension on saturday. Got the parts back from surface treatment early saturday and proceded to mount the ball joints on the Aarms. Left went fine....right went....wtf is this! Aaaah of course, another trace of the hit to the front right corner that some PO never fixed correctly. Getting another A-arm is managable, will cost me about $150 to get one and get it mediablasted and powdercoated. Sadly tho the bearing races are stuck to the old one and not coming off. I've emailed Elephant racing hoping to purchase a pair of loose races. Annoyed with this I started on the rear suspension arms instead, drilled and tapped the holes for the grease nipples, and my M6 thread tap broke off in the last hole.... I left Mr Murphy in the garage and called it a day at that point... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:18 PM |
