Single weber fix?, Has anyone tried to fix the fuel runner issue |
CatDaddy60 |
Feb 4 2013, 09:45 AM
Member Group: Members Posts: 99 Joined: 30-January 13 From: Austin Tx Member No.: 15,451 Region Association: Southwest Region |
Ok I get it the fuel doesn't stay atomized in the runners and this causes poor fuel mileage, drivabillity concerns etc, I understand. But for those of us poor souls who for one reason or another are committed to this carb (the holley weber), has anyone tried heating the runners either electronically or with a subsequent exhaust runner ie type 1 vw and if so did it help with any of the concerns. my second question could anyone post a photo of what the throttle linkage should look like. i have a stock throttle cable and a cobbed together carb from a type 4 kit that has the carb turned 90 degrees and the cable wont reach the carb. any help will be appreciated.
McMark |
Feb 4 2013, 10:45 AM
Use the aluminum or paper gaskets between the heads and the intake runners to transmit as much heat as possible. If you use the plastic 'phenolic' spacers your intake runners will stay cooler.
Otherwise, just do your best to tune it until you can get something better. |
Lo-Fi Version | Time is now: 13th May 2024 - 03:21 PM |
