Argh! I need help with my messy garage, 12 point program needed |
DNHunt |
Nov 14 2004, 10:40 AM
When did the nuke hit? This morning I slipped on a tool on the floor. I have to clean this mess up or I may get hurt. How do you guys keep your work areas clean? I hate cleaning up. (IMG:style_emoticons/default/mad.gif)
Dave Attached image(s) |
GaroldShaffer |
Nov 14 2004, 10:43 AM
Mine is spotless (IMG:style_emoticons/default/wink.gif) just becareful when opening ANY doors (IMG:style_emoticons/default/cool_shades.gif) (IMG:style_emoticons/default/laugh.gif)
xsboost90 |
Nov 14 2004, 10:46 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
i try to clean up at the end of each time im in there, just make small piles of tools and parts etc., and the next time im in there before i start i put the tools away and start all over.
IronHillRestorations |
Nov 14 2004, 10:58 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
It happens, I call it "heat of the battle". Slip the teenager a $20 and have him clean it up!
Rusty |
Nov 14 2004, 11:03 AM
If I'm alone...it's clean as you go. If I don't, I'll never find the same tools again.
Otherwise - the solution is a Toolwench. -Rusty (IMG:style_emoticons/default/smoke.gif) |
rhodyguy |
Nov 14 2004, 11:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the engine would'nt take up so much room if you installed it in your car.
kevin |
bperry |
Nov 14 2004, 12:42 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Wow, I'm surprised that the workmate can support the weight
of an engine. I'd use something a bit beefier. I found that just keeping a 55 gallon trashcan lined with heavy 3 mil contractor bags (home depot) in the corner helps alot. Get the heavy ones the thin ones will tear and ruin your day. My technique is to clean up and actually put away ALL the tools when ever there is a major task completed or at the end of each day before I go to bed. It it too tempting and easy to just keep going and blast right into the next task or leave the tools out for the next day. Most of the time the tools and supplies of the next task are different anyway and in some cases, I may not get back to the task for a few days. I also have a designated place or case for each and every tool. Once all the tools are put away, most of what is left is crap or stuff that goes in the waste bin anyway so clean up isn't that bad. And as bad as your space looks, I bet within an hour you could have it cleaned up. --- bill |
Qarl |
Nov 14 2004, 01:07 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Step #1 - Send your pretty car with new engine to Qarl
spare time toys |
Nov 14 2004, 01:19 PM
When did you come by and take a photo of my shop. OH the floor aint pink from overspray never mind. (IMG:style_emoticons/default/beerchug.gif)
redshift |
Nov 14 2004, 01:25 PM
Dave... THAT LOOKS LIKE HELL! (IMG:style_emoticons/default/smile.gif)
I keep a small roll-around table top that has the set of tools I need for the work I am doing, then I roll-'em back. M |
J P Stein |
Nov 14 2004, 01:29 PM
Hay, that don't look too bad, but I hope none of your patients see that pic......"I let this guy in my mouth?" (IMG:style_emoticons/default/w00t.gif)
Get your youngn' and explain that the father son projects aren't all wine & roses.....there's drudgery involved. He prolly already knows that after cleaning that motor, but he may try to skate.....I would (IMG:style_emoticons/default/laugh.gif) |
Rhodes71/914 |
Nov 14 2004, 02:22 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
I learned from working on boats and in a shop that the best thing to do is put all tools and parts away at the end of the day or end of the project which ever comes first. Try to give everything a place so that it becomes routine when it is time to clean up. This method saves time as well, you won't be hunting for that damn 13mm deep socket agian.
Where did I set those needle nose pliers (IMG:style_emoticons/default/wacko.gif) Peg boards are nice for some, nice tool boxes are good to. I like Miles suggestion of the cart, get the tools out you need for the job at hand and roll it over to where you are working. Oh I have one of those B&D work bench thingies, I don't think I would trust it for an engine stand. Then again I have a 3 year old trying to help me out so safety and cleanliness is a big issue in my garage. Happy cleaning sr |
mharrison |
Nov 14 2004, 03:27 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
You definitely need a place where everything actually goes. If you don't have that, then a) you don't have to put it up and (IMG:style_emoticons/default/cool.gif) you can never find it when you need it.
I have an open carport with two small storage rooms. I found that I had to move my storage UP rather than let it sprawl. I have a ton of stuff hanging on the wall. (Yes there is some rhyme and reason to it!) I also got a large office type wall locker with double doors and heavy shevles. It works great ! Like everybody says, you have to do your best to put the tools up and straighten up when you finish a task, or a day. QUOTE Where did I set those needle nose pliers I think I found them at my house when I cleaned up!!! Heh..heh. |
ChrisReale |
Nov 14 2004, 05:27 PM
Get one of those roll around Craftsman tool boxes that you can stack. Try Sears. Oh, put the engine in your car also.
sj914 |
Nov 14 2004, 05:32 PM
Try throwing some of that stuff in the garbage (boxes, spraycans). And buy more shelves or cabinets so you have a place for the big tools.
Bruce Allert |
Nov 14 2004, 05:33 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
QUOTE(ChrisReale @ Nov 14 2004, 04:27 PM) Get one of those roll around Craftsman tool boxes that you can stack. Try Sears. ...they sell mufflers too (IMG:style_emoticons/default/rolleyes.gif) ....b |
DNHunt |
Nov 14 2004, 06:51 PM
Well I broke down and cleaned it up. I actually have room for a car.
J P Stein |
Nov 14 2004, 08:15 PM
I see the problem....and here's the solution. Cabinets & benches. I bet you could find some seim-employed carpenter to do ya some. (IMG:style_emoticons/default/biggrin.gif)
Attached thumbnail(s) |
J P Stein |
Nov 14 2004, 08:16 PM
Next.
Elliot_Cannon |
Nov 14 2004, 08:32 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Ask Skline to send a picture of his garage and you won't feel so bad about yours! LOL
Cheers, Elliot |
Lo-Fi Version | Time is now: 11th May 2024 - 10:47 AM |
