Impeller Housing, Cheap Casting? |
Allan |
Nov 14 2004, 08:36 PM
Just pulled the impeller housing apart (At least I think that's what it's called). You know the big 2 piece doohickey that bolts onto the end of the motor that the fan sits in. The inside of mine is really rough and cratered like a bad junior high aluminum casting project. The outside looks good. Is it just the way they are made or should the inside be as smooth as the outside?
Nov 14 2004, 08:40 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Headrage @ Nov 14 2004, 07:36 PM) Is it just the way they are made or should the inside be as smooth as the outside? that's the way they are made ... you can actually increase the air-flow (and thus cooling) by making that surface smooth. some people even powder-coat the inside ... (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 11th May 2024 - 02:29 AM |
