I was always curious about tire construction, oops! |
kermit |
Nov 14 2004, 10:25 PM
Member Group: Members Posts: 169 Joined: 2-November 04 From: Millbrae, CA Member No.: 3,049 |
Now that AX season is over in the Bay Area, I took off my worn Kumhos and put on the street tires for the winter.
When I looked closer at my tires, SHEEEESH. It's amazing that I actually did my fastest lap on the last run. 1 of 4, this is the passenger front tire Attached image(s) |
kermit |
Nov 14 2004, 10:26 PM
passenger rear
kermit |
driver rear
kermit |
Nov 14 2004, 10:27 PM
Driver front. YIKES!!
scotty914 |
Nov 14 2004, 10:30 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
of coarse it was your fastest time you had those rare slicks, with steel traction spikes
Demick |
Nov 14 2004, 11:30 PM
Thats nothing Howard. Here is what my last set looked like when I was done. I even had to drive home from the autox on this tire.
Demick |
Demick |
Nov 14 2004, 11:31 PM
Helps to attach the picture.....
kermit |
Nov 15 2004, 11:21 AM
QUOTE(Demick @ Nov 14 2004, 09:31 PM) Helps to attach the picture..... Ok, you win (IMG:style_emoticons/default/pray.gif) |
Joe Bob |
Nov 15 2004, 04:22 PM
Running a little excessive camber are we? If not intentional....ya need an alignment....
Have you checked inside, middle and outer temps after a hot run? |
kermit |
Nov 15 2004, 11:48 PM
QUOTE(mikez @ Nov 15 2004, 02:22 PM) Running a little excessive camber are we? If not intentional....ya need an alignment.... Have you checked inside, middle and outer temps after a hot run? Mike, don't know if you were referring to Demick or myself, but it seems that we both do not have enough negative camber. I know I need a lot more, I only have about 1.5 in the rear, but that is because I suspect I have a bent arm. I can get almost 3 on one side, but only 1.5 on the other, so the lowest common demoninator wins <_< Too cheap to buy a pyrometer, or whatever the thing is called... but I do know people that totally swear by it. |
redshift |
Nov 15 2004, 11:50 PM
Just on the other side of all that metal stuff, is 914 heaven.
(IMG:style_emoticons/default/huh.gif) YIKES! M |
Andyrew |
Nov 16 2004, 01:52 AM
I flatspotted 4 hoosers on braking...
all the way to the cords.... Yup, Bummed me out.... |
Lo-Fi Version | Time is now: 10th May 2024 - 10:43 PM |
