any tips and tricks for splicing into old brittle wiring?, need to replace the wiring to the tail light switch |
bradtho |
Feb 19 2013, 06:22 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
first thing first, I've tested the reverse light system and the switch works fine. If I squeeze the snapped wires together I can get the backup lights to turn on.
So I need to replace a section of this harness. I've used a solder iron before and had success, but its not like I really know what I'm doing. 1) I'm going to need to remove the pin connectors and put them on my replacement wires. I'm assuming I can separate them from the old wires reasonably easy with a normal solder iron and simple re-solder to new wires. anything else I should expect here? My understanding is these pins are NLA, so want to make sure I don't ruin my good existing set. 2) the wire is pretty stiff all the way back to the engine tin. I'm hoping to replace as little as possible, maybe start with just 2in and see if I can get it working. Is that a bad plan since it's likely to break again? the wires inside the engine comp aren't nearly as stiff. I'd like to keep the existing harness. solder? butt splice? Is this a losing battle with 40 yr old wires? |
toolguy |
Feb 19 2013, 07:43 PM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
You can get the correct color of wire from a wrecked 914 wiring harness or someone on here is sure to have a few feet of what you need. . I keep a box full of old Porsche wiring and have spliced out old wire before. . . . . the wire is usually only hard where it has been exposed to the heat of the exhaust. . . the "bullet' ends are soldered on and can be removed and reused. . . get a new rubber cover for the switch before you start. . Often the older copper wire is hard to get solder to stick. . . scrape the wire with a knife edge to expose fresh copper, and be sure to use soldering flux. . . l I found plastic covering identical to original at a surplus electronic shop. . use that and some shrink tub and it will look just like OE. . .
Lo-Fi Version | Time is now: 17th May 2024 - 11:38 PM |
