any tips and tricks for splicing into old brittle wiring?, need to replace the wiring to the tail light switch |
bradtho |
Feb 19 2013, 06:22 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
first thing first, I've tested the reverse light system and the switch works fine. If I squeeze the snapped wires together I can get the backup lights to turn on.
So I need to replace a section of this harness. I've used a solder iron before and had success, but its not like I really know what I'm doing. 1) I'm going to need to remove the pin connectors and put them on my replacement wires. I'm assuming I can separate them from the old wires reasonably easy with a normal solder iron and simple re-solder to new wires. anything else I should expect here? My understanding is these pins are NLA, so want to make sure I don't ruin my good existing set. 2) the wire is pretty stiff all the way back to the engine tin. I'm hoping to replace as little as possible, maybe start with just 2in and see if I can get it working. Is that a bad plan since it's likely to break again? the wires inside the engine comp aren't nearly as stiff. I'd like to keep the existing harness. solder? butt splice? Is this a losing battle with 40 yr old wires? |
IronHillRestorations |
Feb 20 2013, 09:33 AM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Clean up the harness before you do anything.
Stair step your splices so your harness won't have a big pregnant bulge in one spot. Solder and double heat shrink. Just be sure to put the heat shrink on before you solder. Read up on correct soldering techniques so you don't end up with a cold solder joint. Double check your completed work with an ohm meter to make sure all is correct before putting into service. You can help stiff brittle wires into submission with gentle use of a heat gun, just take care as you can do damage if you aren't careful. Silicone spray helps get wires through grommets. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:53 AM |
