Need info on where to find cancel ring for Momo Hub, Original VW cancel ring no good on Momo Hub |
Vysoc |
Feb 28 2013, 08:13 PM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello World,
I had a chance to buy the sweet Momo wheel from my first Porsche 911SC back, after I sold the car, and was happy to get it. I took the Dino wheel off of my current 914 but the cancel ring from the original Porsche/VW wheel worked with the Dino Hub but will not work with the Momo 245 Hub I have. Is there a source to get the turn signal cancel ring for this hub out there somewhere? Thank you all!!! Vysoc (IMG:style_emoticons/default/flag.gif) |
914Sixer |
Feb 28 2013, 08:26 PM
Evil Bay? thesamba.com ?
Mike Bellis |
Feb 28 2013, 08:31 PM
Easy!
A Porsche 924 stock steering wheel has the same ring. EDIT The momo 8002 uses the same ring. Not sure about yours. |
Vysoc |
Mar 1 2013, 06:42 PM
I drilled holes in the stock VW cancelling ring and although it does not center up perfectly it does work to cancel both left & right turn signals.....so now if I can get the horn to work I am good to go.
Thanks, Vysoc (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:21 PM |
