Fixed! Thank you all!, Carbs! |
ThePaintedMan |
Mar 6 2013, 09:46 AM
Good to hear. Sorry, you didn't mention the reason why it was urgent. Glad you fixed it!
KaptKaos |
Mar 6 2013, 12:53 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
The holding Nut for the needle pump came loose, so the Float where stocked at empty but the pump was cramped close so the right side was starving for fuel (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/dry.gif) ! The who what where? (IMG:style_emoticons/default/confused24.gif) |
FourBlades |
Mar 6 2013, 01:53 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
The holding Nut for the needle pump came loose, so the Float where stocked at empty but the pump was cramped close so the right side was starving for fuel (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/dry.gif) ! The who what where? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/popcorn[1].gif) Glad you fixed it! John |
ChrisFoley |
Mar 6 2013, 06:49 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
needle valve seat came loose, contributing to a sticking float, which starved the carb for fuel.
makes sense if it was never tightened properly at the factory. It does seem that new carbs, whether Weber or Empi, need to be rebuilt before installation. I've seen float level settings way off more than once, among other problems. Same is true for Mallory distributors. They have numerous possible problems which must be resolved up front to avoid performance issues. |
mrbubblehead |
Mar 6 2013, 07:11 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
needle valve seat came loose, contributing to a sticking float, which starved the carb for fuel. makes sense if it was never tightened properly at the factory. It does seem that new carbs, whether Weber or Empi, need to be rebuilt before installation. I've seen float level settings way off more than once, among other problems. Same is true for Mallory distributors. They have numerous possible problems which must be resolved up front to avoid performance issues. yes. im sure they're not built in lab like conditions... |
CG-914 |
Mar 6 2013, 09:52 PM
Member Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
You hit the nail on the head Chris and I'm glad I got the distributor from you!
You said 50 idle jets... The idle jet adjustment screws are pretty far out, It seems like 60 would run easier but that is just a speculation from a guy just starting to scratch the carburetor surface! |
Lo-Fi Version | Time is now: 4th June 2024 - 05:11 PM |
