Pop up headlight delete? |
John1180 |
Mar 7 2013, 11:45 PM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
I've been looking for some ideas for an alternative to pop up headlights. Haven't found anything in search. Any ideas or pics?
horizontally-opposed |
Sep 17 2020, 10:52 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
The drop-down headlights are the setup I hope someone will do, with the stock headlight "hole" on each side of the hood filled by one piece of steel (or?) instead of the one Porsche had to use with the separate "brow." Back of the panel drops down to expose modern LED lights or projector setup. Wouldn't take a lot of drop down, and would result in a very clean look.
Have never liked the "brows" in front of the 914's headlights, and always love the shape of the headlight hole when people are putting their cars back together. (IMG:style_emoticons/default/wub.gif) |
ri914 |
Sep 18 2020, 05:21 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
The drop-down headlights are the setup I hope someone will do, with the stock headlight "hole" on each side of the hood filled by one piece of steel (or?) instead of the one Porsche had to use with the separate "brow." Back of the panel drops down to expose modern LED lights or projector setup. Wouldn't take a lot of drop down, and would result in a very clean look. Have never liked the "brows" in front of the 914's headlights, and always love the shape of the headlight hole when people are putting their cars back together. (IMG:style_emoticons/default/wub.gif) That is a great idea. If someone wants to drop off a project car or send one ill do it. Should not be hard to use original parts. I could spin the door motor 180deg to have them pop down. You will have to not care about cutting the factory metal a bit. |
thelogo |
Sep 18 2020, 09:00 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
The drop-down headlights are the setup I hope someone will do, with the stock headlight "hole" on each side of the hood filled by one piece of steel (or?) instead of the one Porsche had to use with the separate "brow." Back of the panel drops down to expose modern LED lights or projector setup. Wouldn't take a lot of drop down, and would result in a very clean look. Have never liked the "brows" in front of the 914's headlights, and always love the shape of the headlight hole when people are putting their cars back together. (IMG:style_emoticons/default/wub.gif) That is a great idea. If someone wants to drop off a project car or send one ill do it. Should not be hard to use original parts. I could spin the door motor 180deg to have them pop down. You will have to not care about cutting the factory metal a bit. (IMG:style_emoticons/default/agree.gif) Someone step up and try this ... So the vector will live on . in more than just (my) and gerald weigart mind (IMG:style_emoticons/default/chair.gif) |
mgp4591 |
Sep 18 2020, 01:13 PM
914 Guru Group: Members Posts: 5,372 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
The drop-down headlights are the setup I hope someone will do, with the stock headlight "hole" on each side of the hood filled by one piece of steel (or?) instead of the one Porsche had to use with the separate "brow." Back of the panel drops down to expose modern LED lights or projector setup. Wouldn't take a lot of drop down, and would result in a very clean look. Have never liked the "brows" in front of the 914's headlights, and always love the shape of the headlight hole when people are putting their cars back together. (IMG:style_emoticons/default/wub.gif) That is a great idea. If someone wants to drop off a project car or send one ill do it. Should not be hard to use original parts. I could spin the door motor 180deg to have them pop down. You will have to not care about cutting the factory metal a bit. (IMG:style_emoticons/default/agree.gif) Someone step up and try this ... So the vector will live on . in more than just (my) and gerald weigart mind (IMG:style_emoticons/default/chair.gif) Take some measurements and do the math...I don't think you'll be able to fit the headlights like you'd like. Having said that, I think it's almost a challenge... (IMG:style_emoticons/default/shades.gif) |
Sep 18 2020, 01:26 PM
Take some measurements and do the math...I don't think you'll be able to fit the headlights like you'd like. Having said that, I think it's almost a challenge... (IMG:style_emoticons/default/shades.gif) The Vector solution is the solution. Question will be what headlights, and LEDs may be needed. Nice thing is LED lighting is pretty incredible these days. There's got to be something that is plain enough, as wide as a round H4, and not very tall. Ideally, it's a rectangle or has two round circles...and ideally it offers high/low beams. If my 914 wasn't so period correct, I'd be pretty interested in doing this. |
thelogo |
Sep 18 2020, 02:32 PM
Take some measurements and do the math...I don't think you'll be able to fit the headlights like you'd like. Having said that, I think it's almost a challenge... (IMG:style_emoticons/default/shades.gif) The Vector solution is the solution. Question will be what headlights, and LEDs may be needed. Nice thing is LED lighting is pretty incredible these days. There's got to be something that is plain enough, as wide as a round H4, and not very tall. Ideally, it's a rectangle or has two round circles...and ideally it offers high/low beams. If my 914 wasn't so period correct, I'd be pretty interested in doing this. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/pray.gif) I thought it was just me and weigart but ill order another straight jacket for horizontally-opposed |
Lo-Fi Version | Time is now: 15th May 2024 - 04:58 AM |
