Opinions- Cutting notch in head for ring CHT sender |
ChrisFoley |
Mar 12 2013, 02:34 PM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
All the 12mm ring t/cs from aircraft insrument mfrs are just 1/2" ring terminals, and the 14mm ones are just reamed out 1/2" ring terminals. I thought that the gauges were calibrated to the terminal though,... Nope. The ring terminal is only a thermally conductive end for the thermocouple wires, which are typically welded together in a carbon arc. The weld bead is crimped in the terminal. |
mrbubblehead |
Mar 12 2013, 02:37 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
All the 12mm ring t/cs from aircraft insrument mfrs are just 1/2" ring terminals, and the 14mm ones are just reamed out 1/2" ring terminals. I thought that the gauges were calibrated to the terminal though,... Nope. The ring terminal is only a thermally conductive end for the thermocouple wires, which are typically welded together in a carbon arc. The weld bead is crimped in the terminal. i just stick my wires in the end of the terminal and smash them in my press... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 10:10 PM |
