Oil temp gauge and sender help |
913B |
Mar 12 2013, 07:33 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Ok, so here are my parts, can you please confirm which sender I should use with the proper gauge. I am thinking the 200c sender with the 200c gauge, am I safe to assume that ?
Thank you |
Mar 12 2013, 08:59 PM
I have been told by the guys at Palo Alto Speedo that that the senders are pretty much the same resistance range, so if you match the temperature range you are at least going to be close.
If that is true (for gauges as old as ours) then the 200C sender should work great. If they're not, then I have no clue what would work... --DD |
McMark |
Mar 12 2013, 09:56 PM
It's a bit cumbersome but you could use boiling water to double check rough accuracy.
reharvey |
Mar 13 2013, 06:48 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
It's a bit cumbersome but you could use boiling water to double check rough accuracy. (IMG:style_emoticons/default/agree.gif) I've done this many times. When you have the sender in boiling water mark the gauge where the needle is and you'll know when you engine oil is at 212deg. |
Lo-Fi Version | Time is now: 14th May 2024 - 06:31 AM |
