How your Headlight Motors Work., A description with pictures. |
ClayPerrine |
Nov 18 2004, 09:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
NOTE: DUE TO MY NOT LOOKING AT THE WIRING DIAGRAM BEFORE POSTING THIS, I HAVE EDITED IT TO REFLECT REALITY!! (IMG:style_emoticons/default/headbang.gif)
I noticed that there is a lot of questions out there relating to how the headlight motors work. So I put this together to see if I can clear it up. The headlight motor circuit functions like a 3 way light switch in your house. You all have seen them. The one you can turn on at the bottom of the stairs and turn off at the top. Well, when you turn on the headlights in a 914, you turn on the headlight motor. It's rotation turns off the headlight motor when the lights are up, using a set of wiper contacts in the motor. In the first diagram below, I outline the headlight circuit with the lights in the down position. Attached thumbnail(s) |
ClayPerrine |
Nov 18 2004, 09:10 AM
In the next picture we see the headlight circuit while the motor is running to raise the headlights.
The headlight switch has connected to the on contact, supplying power to the "closed when down" wiper contact on the headlight motor. The common connection from the wiper contacts then supplies power to the relay to energize it. This connects pin 87 to pin 30 providing power to the headlight motor and starting it running. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:59 PM |
