3 Pages V < 1 2 3
> 911 & 914/6 Upper Steering Bearing, I found a replacement - any interest?
McMark
post Apr 2 2018, 06:25 AM
Post #41
914 Freak!
I do. (IMG:style_emoticons/default/sunglasses.gif)
Anybody else want one at $60 shipped?
rudedude
post Apr 2 2018, 07:31 AM
Post #42
I'll try one for my 911. Also need a crank position sensor if you still have. PM me thanks
sbsix
post Apr 2 2018, 10:28 AM
Post #43
only the lead dog enjoys a change in scenery...
DB9146, the OE upper steering bearing does not cure any steering wheel movement if you have some "slop" in the steering, as far as a 914-6 goes.
McMark's bearing works perfectly and it cured my wobble. I can't believe it's already been 5 years since I commented on this thread.
db9146
post Apr 2 2018, 12:52 PM
Post #44
Yes, since I bought mine several years ago, I have had more movement in mine than I like.
If replacing the OE upper steering bearing doesn't fix it, then I wonder what that bearing is for? What is it "bearing" against?
I only considered going the OE route because I thought it a better solution for me since there is no shim fitting needed and I really have no access to an metal other than what I can buy at the local hardware store.
McMark replied to my post this morning 1st thing and got back to me with the price, so kudos to McMark for speed!
sbsix
post Apr 2 2018, 02:52 PM
Post #45
The OE bearing just centers the steering column. You would think it would also take care of the movement as well.
McMark's bearing not only fixes the issue, but at $60 it's substantially cheaper than the Porsche OE upper steering bearing!
The hardest part of this fix is putting all the plastic steering column cover pieces back in place.
mb911
post Jan 18 2019, 04:23 PM
Post #46
Does anyone know the retrofit part number on these? I am waiting to hear back from mcmark.. If anyone else knows I would appreciate it..
post Jan 18 2019, 04:35 PM
Post #47
914-6 GT in waiting
I think it’s a shim and a bearing to replace the oem bearing. I could use one too.
3 Pages V < 1 2 3
- Lo-Fi Version Time is now: 12th November 2025 - 07:12 AM
