914 Chassis Stiffness, want input on chassis stiffness measurements |
Curbandgutter |
Mar 14 2013, 12:30 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
I want to check the stiffness of the 914 chassis two ways: the flexural stiffness (as in measure the shock tower movement as you lift it from the middle), and the torsional stiffness ( measuring the shock tower movement as you lift three wheels).
Then I want to input a 914 chassis into a 3d structural software that I use. I will design a tube chassis and check the flexural and torsional stifness with different tubing and thickness layouts. Then construct the tube chassis and compare the real world results. I want input from others as to how they would go about doing this. Or maybe give me some pointers. Or maybe someone already knows the factory stiffness? What do you think? |
Mike Bellis |
Mar 15 2013, 05:26 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Curbandgutter |
Mar 16 2013, 09:43 AM
Thank You. It's nice to be back. Looks like the 914 enthusiasm is still out there. Nice to be in it when there are many other enthusiast that can add to your knowledge. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:01 PM |
