914 Chassis Stiffness, want input on chassis stiffness measurements |
Curbandgutter |
Mar 14 2013, 12:30 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
I want to check the stiffness of the 914 chassis two ways: the flexural stiffness (as in measure the shock tower movement as you lift it from the middle), and the torsional stiffness ( measuring the shock tower movement as you lift three wheels).
Then I want to input a 914 chassis into a 3d structural software that I use. I will design a tube chassis and check the flexural and torsional stifness with different tubing and thickness layouts. Then construct the tube chassis and compare the real world results. I want input from others as to how they would go about doing this. Or maybe give me some pointers. Or maybe someone already knows the factory stiffness? What do you think? |
sixnotfour |
Sep 11 2016, 08:56 AM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Up Fixxin Der Porsche vol. VIII pg 241
I am pretty sure...anyway Bob Garretson / Bruce Anderson did an article on 914 chassis analysis on a shaker table ... I posted a scan of the article ,, but cant find and tired of looking , may answer or conform some thoughts... |
Lo-Fi Version | Time is now: 6th May 2024 - 06:32 AM |
