7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
Checked search and Haynes...no go. I don't remember either. (IMG:style_emoticons/default/confused24.gif)
The mount for the ashtray has rails and looks like there are two small screws on top in front and there are four other holes in a square pattern on top. When I put the piece in there don't see any mounting area for the four holes...just the two small screws in front; empty behind. Are there only two holes that hold this in? in front? The back just hangs there. |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,889 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
It's been awhile, but I remember two screws and the back slides into some sort of hook. The two screws just hold it in place.
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
That's how my 72 is. Two screws in the front.
Griffinroydonald |
Newbie ![]() Group: Members Posts: 49 Joined: 21-January 10 From: Kings Mtn N.C. Member No.: 11,274 Region Association: None ![]() |
The hook in the back latches to the metal dash frame and the screws keep it in place. Without the hook you get movement when the ashtray is pulled out.
7TPorsh |
Thanks you all your help.
Note to everyone...before posting silly questions like this one. Turn the piece around and see if you had it backwards. "Nice tree! Where was that forest you were talking about?" |
Lo-Fi Version | Time is now: 3rd July 2025 - 10:33 AM |
