> EPDM Caliper 1/2 Seals, Square Cut Caliper 1/2 Seals
Eric_Shea
post Mar 20 2013, 03:32 PM
PMB Performance
Everyone's been asking for the real deal seals and, here they are.
You will need 4 of these to do a pair of solid rotor (914 front and rear) calipers and 8 of these to do a pair of vented rotor calipers (914-6 fronts with spacers)
These are the proper EPDM rubber seals to use when rebuilding your calipers. These are the real deal gang... the square cut factory seals you've been hunting all over for. These seals are rated at over 10,000 PSI. Now you can sleep at night knowing that at least the seals are correct in your rebuild!
Of course, these come in our kits but, if you didn't figger that out in advance and you made a booboo in your purchasing decision, you can always visit us at the friendly link below and we'll be happy to bring your seal kits up to our standards. (IMG:style_emoticons/default/biggrin.gif)
http://www.pmbperformance.com/catalog/item...552/9694936.htm
- Lo-Fi Version Time is now: 9th June 2026 - 04:15 PM
