| 76-914 |
Mar 24 2013, 09:26 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
As revealed earlier, I don't know (IMG:style_emoticons/default/stromberg.gif) about suspension. I did know enough to listen to the pros and have taken Eric's set up advice. (guess who has new Bilsteins coming (IMG:style_emoticons/default/biggrin.gif) ) My question is this; how do I identify what I currently have? Is this done by the number of coils? Is it stamped somewhere? Color coded? Here is a shot of mine. And...what does 100,120,140lb represent? What happens at a given value? TIA, kent
| McMark |
Mar 24 2013, 10:48 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
If my math is right, I think all the stock springs listed below are around 150 pounds. AFAIK, the three variations are about 14 pounds between the lowest rate mentioned and the highest.
EDIT: I am wrong. Attached image(s)
| Dave_Darling |
Mar 24 2013, 11:38 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I think your math is wrong, McMark. Specifically, not accounting for the "P at L1 = 239mm". I believe they're talking about a pressure at a given spring length, though it is possible it could be a given amount of reduction in length.
The oldest info we have is that the stock springs are on the order of 60 lbs. The way we rate springs in the US is in "pounds per inch". That means pounds of force that it takes to compress the spring one inch. Most springs are relatively linear in rate through most of their range, meaning that compressing the spring two inches takes twice as many pounds as compressing it one inch. Some are "progressive rate" springs, where compressing the spring two inches takes more than twice as much force. --DD |
| 76-914 |
Mar 25 2013, 08:07 AM
Hey guys, thx for the quick response but I guess you went over my head because I still don't know what I've got or what was said. I did find this but doesn't mention the 914. http://forums.rennlist.com/rennforums/924-...color-code.html Maybe someone could tell me who sells 140# replacement springs or how to test existing springs to determine which I have.
| ThinAir |
Mar 25 2013, 02:06 PM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
I'm wondering too about this. Since mine has non-stock shocks, I'm guessing the PO also replaced the springs. I'd like to be able to figure out what I've got.
| Dave_Darling |
Mar 25 2013, 02:27 PM
The rate is "pounds of force per inch of deflection". That suggests how you would test it:
Weights to put on the end of the spring, and a ruler to measure how far it compresses. Take measurements with different amounts of weight. lbs of weight / inches of compression == lb/in spring rate. ...Or you take them to a shop that has a spring tester, which does the same sort of thing with much more precision. --DD |
| McMark |
Mar 25 2013, 04:39 PM
QUOTE I think your math is wrong, McMark. Yup. I was wrong. Found a spring rate calculator that takes into account wire size, number of coils, etc. And came up around 80 pounds. Of course, that's just rough numbers and for new springs. I don't have any idea of the rate of decay on spring rates. But between 60-80 pounds for stock springs may be about right. |
| SirAndy |
Mar 25 2013, 05:47 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Weights to put on the end of the spring, and a ruler to measure how far it compresses. Take measurements with different amounts of weight. lbs of weight / inches of compression == lb/in spring rate. (IMG:style_emoticons/default/agree.gif) Measure spring length at rest. Put a known weight on top of the spring. Measure difference in length. Plug the known weight (in lbs) and the difference in length (in inch) into the formula above, normalize to 1 inch and voila! (IMG:style_emoticons/default/smash.gif) |
| sixnotfour |
Mar 25 2013, 06:04 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,153 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
If those are KYB's it wont matter..
| r_towle |
Mar 25 2013, 06:06 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Spring ID for the simple minded.
Remove springs, toss them. Order springs you want, install them. Now you know what you have installed. Rich |
| ThinAir |
Mar 26 2013, 12:03 AM
Spring ID for the simple minded. Remove springs, toss them. Order springs you want, install them. Now you know what you have installed. Rich As I recall, 100 pound works well for 914-4 for street driving and once-in-awhile autocross or WCC track day. Any reason to go higher for such use? |
| 76-914 |
Mar 26 2013, 08:37 AM
Weights to put on the end of the spring, and a ruler to measure how far it compresses. Take measurements with different amounts of weight. lbs of weight / inches of compression == lb/in spring rate. (IMG:style_emoticons/default/agree.gif) Measure spring length at rest. Put a known weight on top of the spring. Measure difference in length. Plug the known weight (in lbs) and the difference in length (in inch) into the formula above, normalize to 1 inch and voila! (IMG:style_emoticons/default/smash.gif) I plan on doing just that after I drop the trailing arms. Then I'd like to follow up with a spring test by a pro to verify what I think I already know. If those are KYB's it wont matter.. They are and your right. Erc is sending me some Bilsteins. (IMG:style_emoticons/default/evilgrin.gif) Spring ID for the simple minded. Remove springs, toss them. Order springs you want, install them. Now you know what you have installed. Rich I agree. I want 140# springs. Now tell me where to buy them. |
| Dave_Darling |
Mar 26 2013, 06:38 PM
All over. Performance Products, GPR, Pelican, AA.... Most of your favorite places (did I mention Pelican Parts?) will carry them if they carry 914 stuff at all.
--DD |
| 76-914 |
Mar 27 2013, 07:55 AM
Pelican lists them as NLA as did GPR but I didn't know about Performance Products. They have them for $90 ea., Thanks Dave
| Elliot Cannon |
Mar 27 2013, 11:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I bought 165 lb. progressive springs From Troutman in Temecula. They were at 27831 Sycamore Mesa Road. 909 699 9277. That was about 10 years ago and I'm not sure they are in business anymore. I also got cross drilled rotors from them. Too bad if they're no longer around.
Cheers, Elliot |
| Socalandy |
Mar 27 2013, 05:03 PM
Its got to be Yellow!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
my Eibach 140's came from Pelican via Rebel Racing but they are for the coil over kit and the diam. is different from stock, call Glenn Sager X240
| SLITS |
Mar 27 2013, 05:28 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I bought 165 lb. progressive springs From Troutman in Temecula. They were at 27831 Sycamore Mesa Road. 909 699 9277. That was about 10 years ago and I'm not sure they are in business anymore. I also got cross drilled rotors from them. Too bad if they're no longer around. Cheers, Elliot Troutman moved to the East Coast. House has a caretaker & lots of Porsche parts but they have been gone though. Springs / brake hoses are no longer being made. |
| rgalla9146 |
Mar 27 2013, 06:15 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,943 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I bought 165 lb. progressive springs From Troutman in Temecula. They were at 27831 Sycamore Mesa Road. 909 699 9277. That was about 10 years ago and I'm not sure they are in business anymore. I also got cross drilled rotors from them. Too bad if they're no longer around. Cheers, Elliot Troutman moved to the East Coast. House has a caretaker & lots of Porsche parts but they have been gone though. Springs / brake hoses are no longer being made. Dont mean to hijack but could someone comment on the meaning of the various color paint dabs used on the OE springs ? I know that I've read that yellow was for 914 6 specific springs. True ? if so what does red or green indicate ? |
| ww914 |
Mar 27 2013, 06:32 PM
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
| 76-914 |
Mar 27 2013, 07:01 PM
Pelican lists them as NLA as did GPR but I didn't know about Performance Products. They have them for $90 ea., Thanks Dave If you can't find your 140 lb springs, I have a pair that I bought a couple of years ago that I do not need. Well Hell, PM me a price. That would be a win/win deal. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 13th March 2026 - 11:42 AM |
