| 76-914 |
Mar 27 2013, 07:18 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I bought 165 lb. progressive springs From Troutman in Temecula. They were at 27831 Sycamore Mesa Road. 909 699 9277. That was about 10 years ago and I'm not sure they are in business anymore. I also got cross drilled rotors from them. Too bad if they're no longer around. Cheers, Elliot Troutman moved to the East Coast. House has a caretaker & lots of Porsche parts but they have been gone though. Springs / brake hoses are no longer being made. Dont mean to hijack but could someone comment on the meaning of the various color paint dabs used on the OE springs ? I know that I've read that yellow was for 914 6 specific springs. True ? if so what does red or green indicate ? Yea, me too. I found a post on Rennlist re: color code on some 911's but those started at 160#, IIRC. Nothing on the 914. I'll find out soon enough when I yank mine off and get a better look at them. Right now I can't tell what is painted over and what might be identifying dots. |
| Elliot Cannon |
Mar 27 2013, 10:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Pelican lists them as NLA as did GPR but I didn't know about Performance Products. They have them for $90 ea., Thanks Dave If you can't find your 140 lb springs, I have a pair that I bought a couple of years ago that I do not need. Well Hell, PM me a price. That would be a win/win deal. (IMG:style_emoticons/default/beerchug.gif) If you buy these, I can pick them up for you on the way to the G&R. Unless ww914 is going also. |
| 76-914 |
Apr 4 2013, 12:44 PM
OK, I'm not done with this subject, yet. Just got side tracked. I removed my factory springs (100lb) and they do indeed have 3 green dots. They didn't appear to be dots when viewed from below but as this pic reveals they are identifying marks.
![]() and a shot of the new 140lb Weltmeister's sans colour coding. ![]() ![]() I'll do the squash test (as described by DD) to both old and new springs before I button this up. I want to see how well the old springs have held up for 35 + years. More on this, later. |
| Chris H. |
Apr 4 2013, 03:39 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,077 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Right behind you on this one...my car has KYB's too, which causes everyone who sees them to make the "stink face" (see scotty b's avatar). I don't know any better after 11 years. Bilsteins, Boge's and Koni adjustables are on my short list. Did you consider either of those when you picked the Bils?
| 76-914 |
Apr 5 2013, 08:35 AM
Right behind you on this one...my car has KYB's too, which causes everyone who sees them to make the "stink face" (see scotty b's avatar). I don't know any better after 11 years. Bilsteins, Boge's and Koni adjustables are on my short list. Did you consider either of those when you picked the Bils? (IMG:style_emoticons/default/bye1.gif) Hey Chris, I'm trying to keep busy until a donor car lands in my lap. I didn't check out Koni's or Boges because I have Bilsteins on Whitey and love them. That and I always try to buy from a member vendor. For me, the most important part of any transaction is service "after" the sale. ps Did you see JC's score. I look every day for a donor and he has one land in his lap. Go figure. (IMG:style_emoticons/default/av-943.gif) |
| Chris H. |
Apr 5 2013, 09:34 AM
Very good point. I'll check in with Eric once I get the engine/trans sorted....working on the clutch setup now.
Yeah that EZ30 score was huge! $400 for all that? The newer the better it seems like. Had to replace a lot of brittle hoses, a few sensors, etc. on mine due to the harsh weather around here. Lots of snapped bolts too. Which were fun to drill out. Troll Craigslist...that's where I found mine. Lots of Subies with bad transes out there because its the weak point. |
| struckn |
Apr 5 2013, 01:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
Me Too, Getting ready to do rear springs. I have a set that has a yellow dot and was supposed to be OEM. Someone suggested these were off a 914-6? Is there any reason not to use them on my 914-4? They look like new stock.
Doug |
| messix |
Apr 5 2013, 02:09 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
OK, I'm not done with this subject, yet. Just got side tracked. I removed my factory springs (100lb) and they do indeed have 3 green dots. They didn't appear to be dots when viewed from below but as this pic reveals they are identifying marks. and a shot of the new 140lb Weltmeister's sans colour coding. I'll do the squash test (as described by DD) to both old and new springs before I button this up. I want to see how well the old springs have held up for 35 + years. More on this, later. the progressives will have a softer rate for the first amount of compression and then the final will be 140lb. the tighter spaced coils will compress with the lighter weight and then the coils will stack and the rest of the spring will compress. |
| 76-914 |
Apr 5 2013, 05:22 PM
Very good point. I'll check in with Eric once I get the engine/trans sorted....working on the clutch setup now. Yeah that EZ30 score was huge! $400 for all that? The newer the better it seems like. Had to replace a lot of brittle hoses, a few sensors, etc. on mine due to the harsh weather around here. Lots of snapped bolts too. Which were fun to drill out. Troll Craigslist...that's where I found mine. Lots of Subies with bad transes out there because its the weak point. I want to see your clutch work. I'll go with a 33 in a heartbeat if one appears. 7 main bearings, 9000 crazy RPM's and best of all....wait for it........an existing Mega Squirt map for it. (IMG:style_emoticons/default/shades.gif) Seriously, I'd be washing & waxing Bigkats car for that kind of info. (IMG:style_emoticons/default/biggrin.gif) Me Too, Getting ready to do rear springs. I have a set that has a yellow dot and was supposed to be OEM. Someone suggested these were off a 914-6? Is there any reason not to use them on my 914-4? They look like new stock. Doug As you can see, I'm certainly no expert in this field but I would if your doing shocks. They're only $99 new. In my case, I had no choice as I'm adding weight so I needed a new suspension. QUOTE the progressives will have a softer rate for the first amount of compression and then the final will be 140lb. the tighter spaced coils will compress with the lighter weight and then the coils will stack and the rest of the spring will compress. (IMG:style_emoticons/default/pray.gif) Thx for taking the time to explain that. I love info. (IMG:style_emoticons/default/wub.gif) |
| r_towle |
Apr 5 2013, 07:18 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Very good point. I'll check in with Eric once I get the engine/trans sorted....working on the clutch setup now. Yeah that EZ30 score was huge! $400 for all that? The newer the better it seems like. Had to replace a lot of brittle hoses, a few sensors, etc. on mine due to the harsh weather around here. Lots of snapped bolts too. Which were fun to drill out. Troll Craigslist...that's where I found mine. Lots of Subies with bad transes out there because its the weak point. I want to see your clutch work. I'll go with a 33 in a heartbeat if one appears. 7 main bearings, 9000 crazy RPM's and best of all....wait for it........an existing Mega Squirt map for it. (IMG:style_emoticons/default/shades.gif) Seriously, I'd be washing & waxing Bigkats car for that kind of info. (IMG:style_emoticons/default/biggrin.gif) Me Too, Getting ready to do rear springs. I have a set that has a yellow dot and was supposed to be OEM. Someone suggested these were off a 914-6? Is there any reason not to use them on my 914-4? They look like new stock. Doug As you can see, I'm certainly no expert in this field but I would if your doing shocks. They're only $99 new. In my case, I had no choice as I'm adding weight so I needed a new suspension. QUOTE the progressives will have a softer rate for the first amount of compression and then the final will be 140lb. the tighter spaced coils will compress with the lighter weight and then the coils will stack and the rest of the spring will compress. QUOTE (IMG:style_emoticons/default/pray.gif) Thx for taking the time to explain that. I love info. (IMG:style_emoticons/default/wub.gif) There, I fixed the quotes for you. |
| 76-914 |
Apr 6 2013, 08:26 AM
Thx Rich, I ventured into an area unbeknownst to me. Guess what? Another spring question. The new or progressive springs are shorter than stock. Should the shocks have some pre-load just to keep them tight when the wheel drops or the car is jacked up. I needed to adjust the perch 2 rungs above the lowest setting just to snug them up. What is the correct method? TIA once again, kent
| Dave_Darling |
Apr 6 2013, 09:03 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,328 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Most of the aftermarket springs have a shorter free length than the space for them at full droop. I zip-tied the springs to the upper perches to keep them pointed the right way. And when I jack the car up, I check the spring position as I let it down to make sure the springs sit on the perches.
--DD |
| 76-914 |
Apr 7 2013, 07:34 AM
Most of the aftermarket springs have a shorter free length than the space for them at full droop. I zip-tied the springs to the upper perches to keep them pointed the right way. And when I jack the car up, I check the spring position as I let it down to make sure the springs sit on the perches. --DD Ah hah! Mystery solved. The ass end is so high it looks like an Alley Cat in heat. I'll lower it and use your method. Thx, Dave. |
| PCH |
Sep 8 2019, 04:52 PM
Member ![]() ![]() Group: Members Posts: 146 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California
Anyone know what spring strength 3 red dots signifies?
| SirAndy |
Sep 8 2019, 05:17 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,458 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Anyone know what spring strength 3 red dots signifies? 924S and 944 up to end of MY 86 with M030 - 1 to 3 red dots (IMG:style_emoticons/default/idea.gif) |
| PCH |
Sep 22 2019, 04:23 PM
Anyone know what spring strength 3 red dots signifies? 924S and 944 up to end of MY 86 with M030 - 1 to 3 red dots (IMG:style_emoticons/default/idea.gif) Sweet pea was wearing 944 Shocks? I’ll wondering what stiffness the 3 dots signify. |
Lo-Fi Version | Time is now: 13th March 2026 - 01:35 PM |
