914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS |
Curbandgutter |
Mar 25 2013, 01:12 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killed |
monkeyboy |
Mar 26 2013, 08:39 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Generally cages are unsafe in street cars because you don't wear a helmet on the street. Since the 914 is so small, it's likely in an accident you will bump your head on the roll cage. In that event, the cage always wins.
Curbandgutter |
Mar 26 2013, 12:19 PM
Generally cages are unsafe in street cars because you don't wear a helmet on the street. Since the 914 is so small, it's likely in an accident you will bump your head on the roll cage. In that event, the cage always wins. I see your point. Thank you for the heads up (pun intended) However, since I am making this a speedster, I'm thinking of moving the rear hoop to be more in line with the back of the firewall. |
Lo-Fi Version | Time is now: 19th April 2024 - 12:07 PM |
