914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS |
Curbandgutter |
Mar 25 2013, 01:12 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killed |
Mueller |
Jun 22 2016, 02:07 PM
Are you going to model the suspension?
If so check out GrabCAD, I got the CV joints and center section from there (I modeled the rest) |
Curbandgutter |
Jun 22 2016, 03:18 PM
Are you going to model the suspension? If so check out GrabCAD, I got the CV joints and center section from there (I modeled the rest) |
914forme |
Jun 22 2016, 03:33 PM
The next item on the list is to build the frame table and to mount the 996 to get all of the suspension pick up points tabulated. Then mount the 914 to start building the chassis with the same suspension pick up points built in. I'll be using a plumb bop and a laser meter to measure and square every thing. It's finally coming together. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/popcorn[1].gif) Hoping it is built with I beams and 1/2" plate, so you can weld to it. In reality the I beams are fine, you should make the plate float on individual sections. So you can level the plate separate of the frame. So it looks kinda like this on a much larger scale. Not mine but highly admired from the Garage Journal Forum. |
Lo-Fi Version | Time is now: 18th April 2024 - 05:56 PM |
