914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS |
Curbandgutter |
Mar 25 2013, 01:12 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killed |
Curbandgutter |
Jun 22 2016, 05:35 PM
I am making it out of 4x4 tubing. The tubing has much tighter mill tolerances than hot rolled I-beams. Also square tubing is much better than an I-beam in torsion. To make it out of an I-beam I would have to have it blanchard ground. I'm going with 4x4x3/16 frame with six 4x4x3/16 legs. All cross braced with 4 casters and 6 leveling screws. I'll tack weld on the ground enough so that I can raise and assemble. Then I will level all six legs with my survey equipment. Once leveled I will continue welding all seams a little at a time and from opposing corners so that the table does not warp. Then I will finish in that same Hunter Green as the rotisserie. That small chassis table looks like it's awesome for small projects though.
Lo-Fi Version | Time is now: 17th April 2024 - 03:44 PM |
