914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS |
Curbandgutter |
Mar 25 2013, 01:12 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killed |
Curbandgutter |
Jun 23 2016, 08:01 PM
2g Lateral Load at rear yields a 1/16" lateral deflection
3g Couple at rear yields a 0.114 vertical deflection 3g Couple at front yields a 0.10" vertical deflection 2g Lateral in front yields a WHOPPING 0.70" lateral defelction. This is the worst case. It makes sense too in that the hole where the engine is allows this deflection. I'll have to fix that somehow. I have to wait until the motor is in to add a removable cross brace or just live with it. We will see. |
jd74914 |
Jun 23 2016, 10:08 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
2g Lateral Load at rear yields a 1/16" lateral deflection 3g Couple at rear yields a 0.114 vertical deflection 3g Couple at front yields a 0.10" vertical deflection 2g Lateral in front yields a WHOPPING 0.70" lateral defelction. This is the worst case. It makes sense too in that the hole where the engine is allows this deflection. I'll have to fix that somehow. I have to wait until the motor is in to add a removable cross brace or just live with it. We will see. Nice! Those numbers look great! (IMG:style_emoticons/default/beerchug.gif) If you have time it might be interesting to run a case with a bunch of tubes connecting the rough engine mount locations into one node. At least it'd give you some idea of how much deflection the engine stops (assuming it's not super softly mounted). I bet with an "engine" surrogate in there you'd get a lot of the 0.70" back without making any other changes. Adding a bolt-on stressed panel under the engine (could double as a belly pan for aero) would bring back a bunch of stiffness too. Two pure curiosity questions...How much does it weigh? What software are you using for FEA? |
Lo-Fi Version | Time is now: 25th April 2024 - 05:57 AM |
