914RS4 Tube Chassis 996 Suspension Audi 2.7TT Stage 3, ADDED RECAROS |
Curbandgutter |
Mar 25 2013, 01:12 PM
Senior Member Group: Members Posts: 564 Joined: 8-March 13 From: Murrieta CA Member No.: 15,637 Region Association: Southern California |
Well the dream begins. I'm embarking on the building of a 914 project. Here is the candidate. Bought a roller from LA area. Looks like its not going to be too much rust. Firsts thing will be to strip it. Taking front fenders and rear quarters off. Then sending to Cal Blast for media blasting. I look forward to the knowledge that I can gain from fellow enthusiasts. Plan on taking a lot of pics Stay tuned......
DISCLAIMER: Do not attempt to duplicate anything that is mentioned or illustrated in the entirety of this thread. I do not make any warranties of any kind. If you try to build what I am doing, you take full risk. Do not try this. It may be dangerous to your health and may get you killed |
Curbandgutter |
Jun 27 2016, 04:56 PM
Well the material came in for the the chassis table.
These are the 2x2's that I will use for the webs These are the 4x4's that I will use for the table platform and legs Here are the casters I also picked up some samples of Fine, Medium and Coarse recycled glass for the wet sandblasting. I'll try each to see which works better. Planning on blasting the suspension clean as well. I'll probably be using the fine for the aluminum blasting. I know guys use glass beads for aluminum but that is for delicate surfaces. The suspension is hardly a delicate surface so we will see how it pans out. |
Lo-Fi Version | Time is now: 25th April 2024 - 02:32 PM |
