Erben's Build Thread, adding photos |
Erben914 |
Apr 3 2013, 10:53 PM
Member Group: Members Posts: 137 Joined: 1-January 13 From: Sacramento Member No.: 15,314 Region Association: Central California |
Hey all.
I bought a running and driving 1974 2.0 white (not light ivory) with the appearance package914 in December of 2012. Since then I have joined this awsome site and have been doing some (IMG:style_emoticons/default/sawzall-smiley.gif) , (IMG:style_emoticons/default/welder.gif) and wrenching . I wanted to document what I have been doing and get some more help along the way. I have already met a bunch of generous and helpful people here on 914 world. (jsconst is my hero) I h made it to two events already. The panckake breakfast in Freemont and the Sacramento area meet last month. The best thing about these cars is (IMG:style_emoticons/default/driving.gif) right? I am doing all that I can to fix it up while keeping it on the road. I have a reoccuring nightmare of putting it on jackstands and never driving it again. (See I have learned a lot from this site already) (IMG:style_emoticons/default/av-943.gif) My plan is to get everything working and in good shape before I tear it completly apart, do the hell hole work and bring it back to the original light ivory color. Here is what I have done so far.... Brought it home 150 miles on a trailer. It ran but the guy I got it from said the transmission was going out. It wouldnt go into 1st or reverse without grinding. It just needed the clutch cable adjusted! (IMG:style_emoticons/default/aktion035.gif) Got some ramps after reading about the "Jack stand incident" thanks again world |
Erben914 |
Jan 31 2015, 01:00 AM
I sanded all of the exterior down to bare metal with a d a sander. I did a few panels at a time and did a light rattle can primer just to protect the metal from surface rust while I worked on the rest of the panels. Then right before I was ready to spray my 2k epoxy primer, I re sanded the light primer coat back off. I hate sanding even more than I did before I started. If I had it to do all over again I would pay to have the tub media blasted and sealed with epoxy by a pro.
I stripped the trunks with aircraft stripper and did the same with the rattle can primer. I pounded out an dents or imperfections as much as possible and then skimed those areas with a high quality filler over the bare metal. My body skills are not as good as some of the gurus around here. I have seen work from the "metal surgeon" that I would not even put paint over. Just clear coat it like a delorean Most modern filler products are ok to go over primer. I was taught to to put your filler over a scuffed metal so that is what I did. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:09 AM |
