914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
My fuel pressure is set at 30lbs when the car is not running. When I start the car it read about 60 lbs. is that normal?
The car runs fine. Djet 2.0 (IMG:style_emoticons/default/beer3.gif) |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Paul, nominal psi for a standard T-4 FI system is 30. 60 psi is double what you need. What pump are you running?
914itis |
I have a Bosch 2 port pump, I believe it is stock.
do you read it with engine running? It is at 30 when i shut-off the engine. |
euro911 |
See if you can get a part # off the pump. Is your pressure gauge accurate?
If your gauge IS accurate, the pump may be for a larger displacement engine. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The system runs at about 30 PSI. On shutoff, it usually drops 5-10 PSI and should hold that for at least 20 minutes. If it plunges to 0 on shutoff, there's a leak down problem, either with the pump check valve or the regulator (or, worst case, a fuel leak). Measure it running.
This should be in the garage forum. The Cap'n |
914itis |
Thanks capt'n , I will try another gauge first. I tried to adjust the regulator and it only makes a difference when the engine is off . The gauge didnt move with the engine running as I turn adjust the regulator.
I think the fuel pressure regulator is the culprit. Are they generic? Can I get one from the FLAPS? Admin please move this thread to the garage. |
914itis |
Admin please move to garage.
Cap'n Krusty |
euro911 |
I don't know what '2-port' pump you have installed there, Paul, but it's possible that it's for another make of auto that requires a higher psi (for example, a 3.2L Acura requires 40 psi) (IMG:style_emoticons/default/confused24.gif)
Larger displacement engines require a higher volume of fuel during starting and heavy load, and some have pumps with up to 75 psi. That's why I asked about the part # so we can see what you have there (IMG:style_emoticons/default/popcorn[1].gif) |
914itis |
I don't know what '2-port' pump you have installed there, Paul, but it's possible that it's for another make of auto that requires a higher psi (for example, a 3.2L Acura requires 40 psi) (IMG:style_emoticons/default/confused24.gif) Larger displacement engines require a higher volume of fuel during starting and heavy load, and some have pumps with up to 75 psi. That's why I asked about the part # so we can see what you have there (IMG:style_emoticons/default/popcorn[1].gif) I will post the part number this afternoon. I don't think it's a wrong pump as it was fine for the past couple of months. I think that the fuel regulator may have went bad. I have a spare one that I will try to replace it after work. |
914itis |
Pump part # is 0580463010
I changed the regulator and it is the same result. Heading to the flaps nor for new fuel pressure gauge |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
If you changed the regulator and the problem still exists, you have a pinched or plugged return line.
914itis |
SLITS |
If you changed the regulator and the problem still exists, you have a pinched or plugged return line. If a line is pinched or linked, shouldn't the pressure drop ? The pump, "dead-headed" will put out far more than 30 psig. If the suction line is pinched or plugged you will have little or no pressure at all. If the return line is pinched or plugged you will see the total capability of the pumps' output pressure. If you incorrectly hook up the pressure regulator, you will see the same problem ... high pressure in the fuel rails. |
914itis |
If you changed the regulator and the problem still exists, you have a pinched or plugged return line. If a line is pinched or linked, shouldn't the pressure drop ? The pump, "dead-headed" will put out far more than 30 psig. If the suction line is pinched or plugged you will have little or no pressure at all. If the return line is pinched or plugged you will see the total capability of the pumps' output pressure. If you incorrectly hook up the pressure regulator, you will see the same problem ... high pressure in the fuel rails. Great info , checking return line....... Stand by............ |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Stock pumps are 65 PSI out of the box.
Have you possibly flipped the feed and return lines around? Did you replace the screen in the tank at the fitting? those do get pretty clogged. The Fuel pressure should be at 30 running....much more than that and you are running way to rich. The FI systems on these cars have no compensation so Fuel pressure is a key part of proper tuning.. The injectors just open and close. There is no O2 sensor to give the system any feedback for running to rich...really just the CHT and once it hits a certain running temp its not even part of the equation anymore... rich |
rudedude |
Senior Member ![]() ![]() ![]() Group: Members Posts: 521 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest ![]() ![]() |
If the car runs fine "The car runs fine." why are you concerned?
Just curious? |
914itis |
914itis |
You guys rock! You nailed it again (IMG:style_emoticons/default/poke.gif) . It was a kinked return under the tank. Thanks for all the help.
Lo-Fi Version | Time is now: 19th July 2025 - 12:00 AM |
