College Build Thread, trying to make as nice as i can on a college budget. |
Apr 13 2013, 11:20 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Hey, that's not the first blue 914 to run around that neighborhood! I used to live around the corner a few years ago... (IMG:style_emoticons/default/smile.gif)
(That's in around Cirrus/Stratus/Cumulus, right?) --DD |
ndfrigi |
Apr 13 2013, 11:30 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
lanker88 |
Apr 13 2013, 11:31 PM
Cruis'n World 914 Group: Members Posts: 104 Joined: 16-May 10 From: sunnyvale, ca Member No.: 11,734 Region Association: Northern California |
Hey, that's not the first blue 914 to run around that neighborhood! I used to live around the corner a few years ago... (IMG:style_emoticons/default/smile.gif) (That's in around Cirrus/Stratus/Cumulus, right?) --DD Hey Dave, Yeah i've only seen a few 914s in Sunnyvale area trying to keep atleast one here. Pretty close to there just a few minutes away from there im over by homestead and sunnyvale saratoga. -Luke |
lanker88 |
Apr 13 2013, 11:33 PM
lanker88 |
Apr 14 2013, 11:02 AM
Okay So I've been thinking of a cool way to rearrange my gauge cluster and have been wanting to add temp and oil pressure with that said I have a question. Will the 911 gauges work with the 914? This one in particular? I want to put this where my fuel gauge is on the far left and use a small VDO fuel gauge in a center console ill be installing along with the clock and battery voltage. What do you think?
Apr 14 2013, 12:00 PM
You have to have senders that will work with those gauges. The stock "idiot light" sender will not give a reading for the gauge; you will need a "dual sender". And you'll need a grease gun hose and some adaptor fittings to mount it, because the dual senders are big enough to interfere with the distributor.
If you have the oil temp sender in the "taco plate", you will get some readings on the temp gauge. They won't match the (very tiny) numbers on the gauge, but at least the needle will tell you "warmer" or "cooler". You can get a sender that will read correctly for that gauge, though. If you don't have a sender already, you'll need to come up with a way to mount one down in the sump. See Racer Chris' group buy thread for the "taco plate" setup; it looks pretty neat. Most of the VDO fuel gauges don't have the right range to work with our senders. Some that were intended for use in Bugs do, I think. I'd put an extra light up in the instrument cluster for your low fuel light. The gauge you show doesn't have a light, and it might be nice to have that warning up in the dash rather than down in the console. ....Why yes, I did think a lot about this particular setup before I finally bought one of the triple-gauge kits.... (IMG:style_emoticons/default/smile.gif) --DD |
lanker88 |
Apr 14 2013, 03:24 PM
You have to have senders that will work with those gauges. The stock "idiot light" sender will not give a reading for the gauge; you will need a "dual sender". And you'll need a grease gun hose and some adaptor fittings to mount it, because the dual senders are big enough to interfere with the distributor. If you have the oil temp sender in the "taco plate", you will get some readings on the temp gauge. They won't match the (very tiny) numbers on the gauge, but at least the needle will tell you "warmer" or "cooler". You can get a sender that will read correctly for that gauge, though. If you don't have a sender already, you'll need to come up with a way to mount one down in the sump. See Racer Chris' group buy thread for the "taco plate" setup; it looks pretty neat. Most of the VDO fuel gauges don't have the right range to work with our senders. Some that were intended for use in Bugs do, I think. I'd put an extra light up in the instrument cluster for your low fuel light. The gauge you show doesn't have a light, and it might be nice to have that warning up in the dash rather than down in the console. ....Why yes, I did think a lot about this particular setup before I finally bought one of the triple-gauge kits.... (IMG:style_emoticons/default/smile.gif) --DD Thanks Dave, that gives me a little to think about. I could utilize the "cat" light since its a 75 as a low fuel light haha since its being unused anyway. |
lanker88 |
Apr 22 2013, 01:44 PM
You have to have senders that will work with those gauges. The stock "idiot light" sender will not give a reading for the gauge; you will need a "dual sender". And you'll need a grease gun hose and some adaptor fittings to mount it, because the dual senders are big enough to interfere with the distributor. If you have the oil temp sender in the "taco plate", you will get some readings on the temp gauge. They won't match the (very tiny) numbers on the gauge, but at least the needle will tell you "warmer" or "cooler". You can get a sender that will read correctly for that gauge, though. If you don't have a sender already, you'll need to come up with a way to mount one down in the sump. See Racer Chris' group buy thread for the "taco plate" setup; it looks pretty neat. Most of the VDO fuel gauges don't have the right range to work with our senders. Some that were intended for use in Bugs do, I think. I'd put an extra light up in the instrument cluster for your low fuel light. The gauge you show doesn't have a light, and it might be nice to have that warning up in the dash rather than down in the console. ....Why yes, I did think a lot about this particular setup before I finally bought one of the triple-gauge kits.... (IMG:style_emoticons/default/smile.gif) --DD Thanks Dave, that gives me a little to think about. I could utilize the "cat" light since its a 75 as a low fuel light haha since its being unused anyway. Update: -Installed refurbished vacuum distributor- PO had a vw bug distributor which was causing the bucking and engine dying. -Installed Battery Voltmeter, Oil Pressure, and Oil Temp Gauges(underdash) Pics to soon follow -Valve Adjustment done and other work completed at HPH. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:27 AM |
