What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
Phil Plummer |
Apr 14 2013, 06:32 PM
Member Group: Members Posts: 120 Joined: 7-January 12 From: Edmonton Ab Canada Member No.: 13,973 Region Association: Canada |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif) I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) Well my 916 clone runs awsome and purrs like a kitten on steriods!!! What I did WRONG was listening to Elegant motors in Edmonton Canada When I was sold a 930/10 engine for a good price and yes it is a great Engine , However the owner had quoted 3000 to install Engine in my 914 and of course I supply all parts the moment my check cleared the owner of Elegant motors whom I had made the agreement with ordered me to remove my engine and he was "Too busy to do it" 2 yrs went by and after helping pull several Lotus engines Ferrari and Lambo Trannys as well as picking up parts in hopes of getting shop time ..After some alcohol consumed he admitted he did not have the knowledge to do this conversion by this time I had taken a car that was rust free and ran great and sold the original engine Thus I could not even drive it to PMS or another conversion specialist. I made afew mistakes ..put a fendr ding in the car as things were dropped Etc Greg Collins of Awsome shop in Spruce Grove Ab Canada installed engine and plumbed a nice oil cooler system, collabarated with Richard Johnson and a fine senior in Texas named Wes who is a gold mine of info on wireing. Greg Collins charged less than 4000.00 and the car can now be driven to the body shop where it awaits the flares, double grill,paint and finishes. Those whom I cannot thank enough are: - Richard Johnson-Great motor mount he designed to use with ktronic injection -Brian Day of Patrick motor sports parts for not only selling numerous parts but taking several minutes to offer very valuable advice saving much tme, money and heartache. Wes, the man in Texas for his extensive knowledge on air cooled wireing. Joel at Gt racing for nice headers and advice. Kenedy Engineering World apolstry Pelican parts in particular Glenn at Pelican for his knowledge and direction 20th street Auto And of couse Greg collins of Awsome Shop without whom I have a pile of junk, expensive parts, clutter and grief. Iam thankfull to the 914 world people for advice in many other areas in regard to 914's and conversion-Regards Phil |
Lo-Fi Version | Time is now: 11th May 2024 - 03:06 AM |
