What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
cwpeden |
Apr 14 2013, 08:45 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
What did I do wrong to my 914 today?
Thats an easy one.....I looked under it. And thats when it all went wrong. (IMG:style_emoticons/default/stirthepot.gif) Havent driven for 2 months. Went for a spin this morning and thought I'd forgotten how to shift. Went under to have a look, turned into: Loose mount at end of bar Fixing broken sheet metal Adjust rear brake venting Get ready to rebuild rear calipers (IMG:style_emoticons/default/headbang.gif) And these curious bits of plastic in the firewall boot. I think I found the problem |
euro911 |
Apr 14 2013, 10:21 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
And these curious bits of plastic in the firewall boot. Looks like you found a broken Fahrvergnügen stick man (IMG:style_emoticons/default/laugh.gif) I think I found the problem |
Lo-Fi Version | Time is now: 10th May 2024 - 10:51 PM |
