What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
wndsnd |
Apr 15 2013, 05:53 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Decided to put the fresh air system back into the car. Plugged in blower, pushed over lever, nothing. So I replaced the relay, checked the fuse still nothing. Now I am on my back and looking at the back side of the heater control. There are three varients of white wires for speed control of the blower motor. White, White/Green, and White/Yellow. Found two wires disconnected from control and taped together with masking tape by PO. Found Brown ground dangling and attached to nothing.
So I sorted everything out and was all proud of myself. (IMG:style_emoticons/default/smile.gif) Flipped the lever and heard the fuse pop behind my head. (IMG:style_emoticons/default/blink.gif) Pretty sure I got the wires crossed at the motor plug...... or Maybe control is shorting and that is why the PO had it all butchered up.... (IMG:style_emoticons/default/confused24.gif) Arghhhhhhhh........ |
Lo-Fi Version | Time is now: 11th May 2024 - 07:34 PM |
