What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
Phil Plummer |
Apr 20 2013, 08:23 AM
Member Group: Members Posts: 120 Joined: 7-January 12 From: Edmonton Ab Canada Member No.: 13,973 Region Association: Canada |
Oh I messed up on the OIL TANK with wrecking the threads on the oil tank tight in between inner and outer fender and not much space to manuver So ...tap and die set to the rescue.!!!
Also picked up a beuty set of Stainless mufflers off of the find for cheap like 36.00 ea now have to re-weld on exhaust flanges at a very slight off set as the muffler on the drivers side hits the tail shifter rod..other than that it is a great reward to see this through to the paint and finshing stages. |
Phil Plummer |
Apr 20 2013, 08:24 AM
Oh I messed up on the OIL TANK with wrecking the threads on the oil tank tight in between inner and outer fender and not much space to manuver So ...tap and die set to the rescue.!!! Also picked up a beuty set of Stainless mufflers off of the find for cheap like 36.00 ea now have to re-weld on exhaust flanges at a very slight off set as the muffler on the drivers side hits the tail shifter rod..other than that it is a great reward to see this through to the paint and finshing stages. Appologies on my earlier rant about buying engine then left high and dry by an untrustworthy mechanic. |
Lo-Fi Version | Time is now: 11th May 2024 - 03:01 PM |
