What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
76-914 |
Jun 25 2013, 01:01 PM
Shit. Another entry in the STUPID dept. I need to spread out & strip down the wiring harness that I pulled from the Subaru donor car. As you can see below this will take up valuable garage floor space so I decided to go vertical.
By cutting the 4x8 plywood into 16" strips I was able to cover the garage door panels but not interfere with the hinged movement as it is raised. Raised being the operative word here. That's right. I didn't consider the added weight to the garage door and it wouldn't raise. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 06:00 AM |
