What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
76-914 |
Oct 22 2014, 09:02 PM
A couple of days ago my GPS Speedo quit. As I had just connected a few other items in the console I looked there first. Sure enough I had pulled a wire loose from it's connection. A quick fix then back on the road. Yesterday, I hop in the car and no speedo, again! Shit sticks! So I check the fuse, OK. Out comes the console face again but everything is intact this time. As I put things back I notice a small red wire hanging next to the consoles left side. I thought this is easy but how in the Hell did I do that? Upon closer examination I discover another small red wire torn as well as a white one AND the small coaxial antenae cable ripped in two places. (IMG:style_emoticons/default/WTF.gif) Rat attack? Cat from Hell? Vandalism? Nope. The problem was this DACO. I had run some wires too close to the U-Joint on the steering column and I had stuffed the extra 10' of antenae wire next to it. Once I realized I had ripped the wiring apart with the shaft it made sense. After a couple of hours of splicing and cussing it's working again. I shortened that antenae cable about 10' while I was at it. The moral to this story is that U-Joint is fairly well concealed by the same braces that make it an open invitation to pass thru when wiring. Easily avoided by securing wiring but I got lazy and it bit me in the ass. (IMG:style_emoticons/default/bootyshake.gif) I remember the second it happened, now. I felt a bit of resistance in the wheel then it was gone. I thought (IMG:style_emoticons/default/WTF.gif) , I'll check it later. (IMG:style_emoticons/default/hissyfit.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 02:16 PM |
