What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
914_teener |
Apr 18 2014, 10:29 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Ravi...
You must really love your car.......... BTW....I might need some help dropping my motor to replace the motor mounts I broke when I replaced the suspension. Now you are a pro. |
stugray |
Oct 23 2014, 09:08 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
BTW....I might need some help dropping my motor to replace the motor mounts I broke when I replaced the suspension. Now you are a pro. How about - "dropping the engine to replace the motor mounts only to learn that you do NOT have to drop the engine to replace the motor mounts?" Hopefully does not turn into: "learning that you should not support an engine on a hydraulic jack for more than a few minutes without shoring it up." |
Lo-Fi Version | Time is now: 11th May 2024 - 09:53 PM |
