What did you do WRONG on your 914 Today |
76-914 |
Apr 14 2013, 09:10 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
OK, I'll start. I don't expect that this thread will catch on because, after all, we are men (most of us) and we don't need instructions nor ask directions, right? DD's admission to using the wrong screw on the interior door handle made me realize there may be place for FU's like this and that it could be used in a preventative manner. (IMG:style_emoticons/default/dry.gif)
I can't remember all my FU's (and there have been many) but this one is fresh in my mind as it happened yesterday. After bragging about my new shop press I must point out that it only works as well as the idiot operating it. After re-installing my trailing arms I noticed a very noticeable amount of slop in the hub as I put the wheel back on. I pulled the arm off and found that I had not placed a back up behind the bearing, rather the bearing receiver, when pressing in the hub. As a result the bearing separated appx 1-2mm. Placed it back on the press with the proper back up and 2 seconds later is was properly pressed in. I've come to the sad realization that you can't fix stupid. (IMG:style_emoticons/default/sad.gif) |
McMark |
Nov 9 2014, 03:40 PM
A few weeks ago the turbo 1.7 developed a fuel supply issue. I was going up hill on my way to work and lost power. I pulled over and I waited for my guy to bring the truck and trailer. I could hear the pump running but figured a clogged fuel filter or clogged pickup was restricting flow. Since the shop is super busy right now it's been about a month and I finally had time to get it up on the lift. But before I lifted it I decided I should check for a clogged pickup first. Well apparently my fuel level sender is stuck, because I peeked in the tank and THERES NO GAS!
(IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 03:07 PM |
