What size is the fitting for the oil pressure sender, And where to find the extension hose parts |
stugray |
Apr 20 2013, 11:35 AM
I have seen a few other members who have installed the dual sender unit by using an extension hose from the stock fitting location under the dist.
What parts do I need and where do I find them? I am ordering the dual sender unit from the bird And while I am at it, I assume that I will only need a 80 PSI sender & gauge for a 4, right (not the 150 PSI)? Stu |
Cap'n Krusty |
Apr 20 2013, 01:28 PM
I have seen a few other members who have installed the dual sender unit by using an extension hose from the stock fitting location under the dist. What parts do I need and where do I find them? I am ordering the dual sender unit from the bird And while I am at it, I assume that I will only need a 80 PSI sender & gauge for a 4, right (not the 150 PSI)? Stu The Cap'n |
stugray |
Apr 20 2013, 03:41 PM
Thanks.
QUOTE Sender must match the gauge. I am buying both a sender and a gauge. So I believe that I will never see greater than 80 PSI on one of these engines? Stu |
Java2570 |
Apr 20 2013, 04:04 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
worn |
Apr 20 2013, 07:09 PM
can't remember Group: Members Posts: 3,152 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thanks. QUOTE Sender must match the gauge. I am buying both a sender and a gauge. So I believe that I will never see greater than 80 PSI on one of these engines? Stu I am trying out a short brass pipe nipple and t arrangement. Has to get through the tin, not get in the way, and be removable. I ended up soldering. Engine goes in tommorow. I am bone tired but will add pics then. |
brant |
Apr 20 2013, 09:10 PM
914 Wizard Group: Members Posts: 11,620 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
the brass pipe is not as good as the grease hose.
the brass can work harden and in theory crack at the base of the thread. Stu, which pump is on it ? also are you using the high pressure pistons? I've used both 80 and 150psi if a big pump, with high pressure pistons you may need the 150 psi set up. |
stugray |
Apr 20 2013, 09:34 PM
QUOTE Stu, which pump is on it ? stock pump & piston. I was hoping whatever gauge setup I got it would still work with the better pump when I upgrade. I ordered the 80 PSI just about an hour ago. Stu |
brant |
Apr 20 2013, 09:36 PM
80 psi is good for stock pump.
Valy |
Apr 20 2013, 11:45 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I'm not a fan of the 1/8 NTP since that's not the correct thread.
I use a brake hose as an extender. |
r3dplanet |
Apr 21 2013, 09:12 AM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Apr 21 2013, 11:50 AM
Air hose from a paint ball gun also is correct, and looks better.
rich |
stugray |
Apr 21 2013, 12:22 PM
QUOTE I'm not a fan of the 1/8 NTP since that's not the correct thread. If 1/8" NPT is not the correct thread, what is? I would find it odd for a all metric engine to have a US pipe thread on it intentionally. It is probably one of those cases where the thread is so close that it works fine. Kind of like the seatbelt bolts.... I will just go with the 1/8" MPT. Thanks Stu |
gothspeed |
Apr 21 2013, 01:18 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I'm not a fan of the 1/8 NTP since that's not the correct thread. I use a brake hose as an extender. +1 ... Yes, the 1/8 NPT is not the correct thread, it is only 'close enough' to capture a few threads and deform the rest. A 10mm x 1.0 thread pitch will engage threads all the way down and then you can use a copper sealing washer. |
stugray |
Apr 22 2013, 04:48 PM
Thanks all.
So in other words...."Same as the brake line fitting thread". However I see that the Hella Pressure switch that was in the engine previously is definitely a tapered thread. Is there such a thing as a Metric 10mm NPT? Stu EDIT: Just found this: https://www.pegasusautoracing.com/productde...ls.asp?RecID=55 Metric Pressure Gauge Adapters, M10x1.0 to 1/8" NPT Too bad you have to get the $46 kit when you just need the one... |
ThePaintedMan |
Apr 22 2013, 05:06 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Whatever you do, do NOT use brass tubing. I was at the track this weekend when a race-prepped 911 that had a brass "T" cracked that fitting and sprayed oil everywhere. Not only did he risk dropping oil all over the track, but he could have lost that engine over a $2 part. I don't think people realize how fast oil pours out at 40+ psi.
As brant said, they stress harden and crack. We were able to remove the T and simply thread the pressure switch back into it's original hole and had him back on the track in several minutes. The grease hose and grounding wire works great. You can use a closed, or "blind" grommet to cover up the large hole left in the tin. |
Apr 22 2013, 06:45 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The aftermarket sender for the gauge is also kind of large and a bit heavy. If you put that up on top of a pipe, you've got a nice bit of leverage to help wiggle the pipe around and damage the threaded hole or even crack the boss on the case. Not good.
The threads are tapered pipe threads. I'll have to look into the brake hose ends; M10 tapered pipe threads are otherwise difficult to find in the US. 1/8" NPT seems to work pretty well... BTW, the seat belt threads are in inch size, I think due to some DOT requirements. --DD |
Harpo |
Apr 23 2013, 05:37 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
At the risk of asking a dumb question why not just trim the tin shroud so the larger sender will fit?
David |
Cap'n Krusty |
Apr 23 2013, 06:08 PM
I'm not a fan of the 1/8 NTP since that's not the correct thread. I use a brake hose as an extender. The original oil pressure switch is 1/8" NPT. What makes you think anything else would be correct? The hole in the case is tapered, so threading in a brake hose doesn't assure a good seal, and you'd need a copper gasket on a flanged line. (German brake lines use the taper on the tip to make the seal, NOT the threads. You've introduced a number of BAD things here. Possible (even likely) thread damage to the case, leaks, a gasket to reduce the possibility of leaks, and another junction to deal with farther down the line. For what? The KISS rule applies here ...................... The Cap'n |
Apr 23 2013, 08:32 PM
bradtho |
Apr 23 2013, 11:37 PM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
I've got a dual pole sender with the hose fitting that came off my car recently. all works great. it's listed in the classifieds if you want to get it all turnkey for cheap.
I was hoping to sell with the gauges but will split if you want it. |
Lo-Fi Version | Time is now: 6th May 2024 - 06:44 PM |
