Fuel Injection Help Part 1 |
lsintampa |
Apr 20 2013, 01:44 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
1975 914/4 2.0
Picture is of the LEFT side intake. Question 1 is do I have the correct fuel rail on the left side? Question 2 is what attaches to the middle of the fuel rail? There is a small threaded nipple right in the middle? I'm assuming some sort of bracket? Thanks, Len |
Andyrew |
Apr 20 2013, 02:12 PM
You dont have to make a new thread to post a new picture, You should just "Add Reply" on the bottom right and you can add the pictures and such.
An admin will combine these posts at a later date. |
lsintampa |
Apr 20 2013, 02:15 PM
You dont have to make a new thread to post a new picture, You should just "Add Reply" on the bottom right and you can add the pictures and such. An admin will combine these posts at a later date. I know... I wanted to keep them as seperate items. Thought it would be better that way to keep it simple. |
442nd914s |
Apr 20 2013, 02:45 PM
Member Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
Answer 1: Yes
Answer 2: Nipple in the middle of the rail should have a screw. This port was designed to check fuel pressure. |
TheCabinetmaker |
Apr 20 2013, 06:16 PM
The nipple on the fuel rail is also used for fuel supply to the cold start valve
Lo-Fi Version | Time is now: 18th May 2024 - 05:38 AM |
