| angerosa |
Apr 28 2013, 08:45 AM
Member ![]() ![]() Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
Seems that this year I need to put a little gas into the carb to get the car started initially. I have single Solex carb that no one seems to be able to identify. I'm sure some PO just pulled it off something that was sitting in a junkyard. Once I get car started and it warms up it idles OK but runs rough when you try to drive it. Timing is spot on. Recent (not too many miles ago) tune up with the help of some very knowledgeable 914world brethren. Let’s say it’s a given that there is nothing wrong with the engine. I have an idea of where to go next. I’ve had car for about 7 years. With only what I’ve told you here what’s your opinion?
angerosa Carb question Apr 28 2013, 08:45 AM
kg6dxn If you have to dump gas in it, the throttle pump i... Apr 28 2013, 09:01 AM
ThePaintedMan Agree with Mike. If the carb has never been rebuil... Apr 28 2013, 09:17 AM
angerosa Yes - I agree. Time for a rebuild. I've had it... Apr 28 2013, 10:52 AM
rhodyguy is the one butterfly activated by the what looks l... Apr 28 2013, 12:00 PM
kg6dxn
is the one butterfly activated by the what looks ... Apr 28 2013, 03:24 PM
angerosa
is the one butterfly activated by the what looks... Apr 28 2013, 03:55 PM
angerosa My topic from two years ago looking for carb rebui... Apr 28 2013, 04:10 PM
warpig I've got a set of dual weber 44's with man... Apr 28 2013, 04:33 PM
angerosa
I've got a set of dual weber 44's with ma... Apr 28 2013, 08:20 PM
DBCooper I agree, if you can't pump some gas into the c... Apr 28 2013, 06:39 PM
angerosa
I agree, if you can't pump some gas into the ... Apr 28 2013, 08:37 PM
ThePaintedMan Hmmm.. a search for Solex 32/34 or Solex progressi... Apr 28 2013, 07:36 PM
angerosa
Hmmm.. a search for Solex 32/34 or Solex progress... Apr 28 2013, 08:47 PM
ThePaintedMan http://www.carbkits.com/catalog/pr/c5/3/solex%20ca... Apr 28 2013, 07:38 PM
rhodyguy maybe a ll he needs to do is replace the choke spr... Apr 28 2013, 07:50 PM
kg6dxn You could go to your local auto parts store and ge... Apr 28 2013, 08:28 PM
angerosa
You could go to your local auto parts store and g... Apr 28 2013, 08:42 PM
angerosa And ThePaintedMan wins it! Thanks George...
Apr 29 2013, 06:48 PM
ThePaintedMan Glad I could help and I got something right for on... Apr 29 2013, 08:49 PM
angerosa At what point should this cam bracket actuate the ... Apr 29 2013, 09:01 PM
ThePaintedMan Assuming it works like every other carb (and physi... Apr 29 2013, 09:19 PM
angerosa
Assuming it works like every other carb (and phys... Apr 30 2013, 10:45 AM
ThePaintedMan
So just to confirm... The "at rest" pos... Apr 30 2013, 10:55 AM
angerosa
So just to confirm... The "at rest" po... Apr 30 2013, 11:06 AM
kg6dxn That's a big gap between the cam and pump arm.... Apr 29 2013, 10:18 PM
ThePaintedMan
That's a big gap between the cam and pump arm... Apr 29 2013, 10:22 PM
angerosa
That's a big gap between the cam and pump ar... Apr 30 2013, 10:51 AM
angerosa
That's a big gap between the cam and pump arm... Apr 30 2013, 10:49 AM
kg6dxn Looks like the arm needs to come way down. Where i... Apr 29 2013, 10:42 PM
ThePaintedMan
Looks like the arm needs to come way down. Where ... Apr 29 2013, 10:46 PM
kg6dxn
Looks like the arm needs to come way down. Where... Apr 29 2013, 11:08 PM
rhodyguy as he stated, the choke looks to be wired in the p... Apr 30 2013, 08:46 AM
angerosa
as he stated, the choke looks to be wired in the ... Apr 30 2013, 10:59 AM
angerosa Just got off the phone with the carb rebuild kit s... Apr 30 2013, 03:34 PM
angerosa So everyone is pointing out this distance that jus... Apr 30 2013, 08:13 PM
DBCooper Take off the screws holding in the accelerator pum... Apr 30 2013, 10:12 PM
ThePaintedMan
Take off the screws holding in the accelerator pu... May 1 2013, 09:23 AM
angerosa I will get the accel pump out but can't do it ... May 1 2013, 11:11 AM
angerosa latest news. I got the carb kit and what I thought... May 4 2013, 09:30 AM
angerosa The story picks up here...
So last you knew I was... May 4 2013, 04:13 PM
kg6dxn Now you're at the point where you find the ach... May 4 2013, 04:49 PM
angerosa Thanks Mike - makes a lot of sense. There is a str... May 5 2013, 06:33 PM
ThePaintedMan I agree with what Mike is saying. The longer intak... May 6 2013, 08:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:10 PM |
