Wiper Relay Instructions, with nice blurry pix :-) |
May 20 2003, 12:12 AM
Resident German Group: Admin Posts: 41,581 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
alright, here it is! the pix are (of course) blurry and all, but you should be able to do it yourself after reading this ...
'73 or later: a ) you need to get the additional (optional) wiper relay wire harness i only have a very bad, low res photo of the add-on harness (fig. 2). i supposed i could take mine out again and take a better pic, but for now this has to be enough. the harness includes a Relay-Socket (fig. 1) with 5 female connectors, one in the center, 4 around. the 5 wires are color coded as follows, thickness stated in brackets: brown/black (0.5) blue/black (1.5) red (1.5) green/white (1.5) brown (0.5) the original manual refers to the wiper relay as #91 (see fig. 3 and fig. 5) b ) you need to locate the control wire for the relay the relay control wire is a brown/black wire that comes from your steering column (far left connector, first wire, see fig. 6) and goes in the main harness towards the wiper motor. the wire should end somewhere around the first support bracket (drivers side, see fig. 1) or near the wiper motor itself. c ) find the original 4 wires on the wiper motor (fig. 8) the original wiper motor wires are color coded as follows, thickness stated in brackets: red/black (1.5) green/white (1.0) black/blue (1.0) black/purple (1.0) d ) put the relay wires in line with the original motor wires (fig. 7) 1) remove the original red/black wired. attach the relay red wire (it has a double connector) then put the red/black back on the second pin. 2) remove the original green/white wire and attach it to the relay blue/black wire (male connector) 3) take the relay green/white wire and attach it to the previous original green/white connector on the wiper motor 4) attach the original brown/black wire to the only empty connetor in the relay socket 5) attach the relay brown wire (ground) to a ground of your choice (i used the wiper motor ground) e ) insert the relay get the correct relay, part# 477 955 531 a (see relay pic) f ) now every time you use your windshield washer, the wipers will run for a while, have fun ... g ) run it with electric pump if you have a electric washer pump, you can use the original control wire (brown/black) to also power your pump. simply splice the wire and run it to the pump. (IMG:http://www.sirandy.com/pix/914/wiperrelay/harness.jpg) (IMG:http://www.sirandy.com/pix/914/wiperrelay/bracket.jpg) (IMG:http://www.sirandy.com/pix/914/wiperrelay/relay.jpg) (IMG:http://www.sirandy.com/pix/914/wiperrelay/1.jpg) (IMG:http://www.sirandy.com/pix/914/wiperrelay/2.jpg) (IMG:http://www.sirandy.com/pix/914/wiperrelay/3.jpg) |
Bleyseng |
May 20 2003, 01:33 PM
yes, but does it work now?
Geoff |
markb |
May 21 2003, 10:25 PM
Very well done, Andy. Thanks! BTW, why don't you add it to the 914 info at the top of the page? (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/happy11.gif)
May 28 2003, 11:51 AM
QUOTE(Bleyseng @ May 20 2003, 12:33 PM) yes, but does it work now? yes! finally got all the rest of the wiring sorted out (dash stuff etc.) and tested the relay. didn't work (IMG:style_emoticons/default/sad.gif) so we put it in Lyressa's car and it worked fine. turned out i had made a "bad" crimp connector. oh well, fixed that and it works well now. money's on the way, btw. ... Andy |
johannes |
Oct 18 2013, 03:27 PM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Can you replace "huge domains" with small pictures ?
Oct 18 2013, 03:41 PM
Can you replace "huge domains" with small pictures ? This thread is 10 years old! (IMG:style_emoticons/default/unsure.gif) We've lost a lot of images during the split, i will have to see if i can dig up related images from an old backup, but don't hold your breath. (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 29th March 2024 - 08:00 AM |
