914/4 steering rack play, Anyone has bushing inner and outer dimensions? |
May 8 2013, 12:27 PM
Custom Member Group: Members Posts: 24,623 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
By the way, does anyone happens to have the precise dimensions for the bronze sleeve bushings at the end of each side of the steering rack? /Lars S Again, we determined at the time that every rack housing is a bit different in size. So the outer diameter of each bushing would be unique to that rack housing. We talked about making a kit, but its not easy if you dont have some sort of adjustable spacer. The rack bar itself seems to be very consistant, and you can measure that without removing the rack assembly from the car. I still believe the best bet for you is to find a used steering rack, then rebuild that one in your spare time. Rich |
larss |
May 8 2013, 11:41 PM
Member Group: Members Posts: 429 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Again, we determined at the time that every rack housing is a bit different in size. So the outer diameter of each bushing would be unique to that rack housing. ... Rich Thanks! The bushings are type of "splined" on the outside, could be to take up minor differences in tube diameter? /Lars S |
Lo-Fi Version | Time is now: 20th September 2024 - 04:41 PM |
