Wigglie, Speedometer |
mrholland2 |
May 4 2013, 06:16 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
So, what are the causes of a wigglie speedometer needle?
I just need a list so I can check everything. I think the head unit is fine. The cable is newish. . but not routed in the original manner (and I have not checked it, I didn't do it) Lubing the cable from the top does not help Thanks Sean |
speed metal army |
May 4 2013, 09:08 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Mine started acting haywire.It turned out to be the drive unit in the tranny.The liitle shaft in the drive unit itself had sheared.
bluhun |
May 5 2013, 02:11 AM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
So, what are the causes of a wigglie speedometer needle? I just need a list so I can check everything. I think the head unit is fine. The cable is newish. . but not routed in the original manner (and I have not checked it, I didn't do it) Lubing the cable from the top does not help Thanks Sean Same thing with my speedometer. Since the cable was replaced the needle bounces from zero to thirty until the car gets up to about 30 mph. |
last337 |
May 5 2013, 07:41 AM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
So, what are the causes of a wigglie speedometer needle? I just need a list so I can check everything. I think the head unit is fine. The cable is newish. . but not routed in the original manner (and I have not checked it, I didn't do it) Lubing the cable from the top does not help Thanks Sean Same thing with my speedometer. Since the cable was replaced the needle bounces from zero to thirty until the car gets up to about 30 mph. Mine does same thing as well |
Cap'n Krusty |
May 5 2013, 08:12 AM
A kink in the cable, even a relatively small one, is usually the cause of this.
The Cap'n |
Lo-Fi Version | Time is now: 17th May 2024 - 07:21 AM |
