Stock 914/6 Engine Rubber Mount, 914 375 049 00 / NOS |
DEC |
May 7 2013, 02:34 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
McMark |
May 7 2013, 10:22 PM
Can you measure the height from the bottom edge to the mounting surface? I'm looking to reproduce the 914/6 engine mount on the body, but use a later style 911 rubber (and it's available). But I need to know more about that mount to make sure it's direct replacement.
Actually, the more measurements you can provide the better. (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/german01.gif) |
DEC |
May 8 2013, 03:01 AM
Can you measure the height from the bottom edge to the mounting surface? I'm looking to reproduce the 914/6 engine mount on the body, but use a later style 911 rubber (and it's available). But I need to know more about that mount to make sure it's direct replacement. Actually, the more measurements you can provide the better. (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/german01.gif) Hi Mark, all measurements are in cm/mm if you need some more let me know. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 09:10 PM |
