d-jet question |
d-jet question |
May 8 2013, 10:26 AM
What does the thermo time switch do?
1971 1.7 d-jet |
Spoke |
May 8 2013, 10:29 AM
Is this the cold start injector sensor?
May 8 2013, 10:31 AM
914itis |
I believe it is the sensor for the cold start injector.
ejm |
May 8 2013, 01:12 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The sensor on D-jet in '71 was a thermoswitch. If the temp was low enough it would supply ground to the cold start valve which would spray as long as the starter was engaged. Later they went to a thermo-time switch which would cut the ground to the CSV after cranking for around 10 seconds. This was to prevent flooding on engines wouldn't start.
Lo-Fi Version | Time is now: 17th May 2024 - 09:10 AM |
