Rubber Steering Coupler - pics of NOS example, what I always thought was wear is actually design |
Brian_Boss |
May 9 2013, 03:50 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
This is somewhat of a continuation of a discussion in the classifieds. Thread here: link
Observations: 1) The steel spacers are not tight in the rubber at either end. 2) The holes are tapered from ~16.25mm at one end to slightly over the 14mm OD of the spacer at the other. 3) The coupler is symmetrical with steel plates bonded to both ends. Speculation: 1) Most of the ones I have seen, which I thought were worn, are not. Mark expressed the same thought in the other thread. 2) The coupler does not seem to work the way I thought it did. The torque from turning the steering wheel is not transmitted by pressure against the rubber by the bolts/spacers. Since the yokes on the rack and column are clamped solidly to the steel plate on the opposite end of the coupler, the torque is really transmitted by a sheering force on the rubber. The holes in the rubber are relieved to allow some flex without binding. Pictures of the NOS example |
veltror |
May 10 2013, 03:10 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Porsche Classic have started to remake these
Lo-Fi Version | Time is now: 21st May 2024 - 02:41 AM |
