My turn at motorcycle Throttle bodies, making progress |
Mark Henry |
May 10 2013, 10:57 AM
Like I need another project... Beginning to be as bad as Dr Evil (IMG:style_emoticons/default/laugh.gif) ... (IMG:style_emoticons/default/huh.gif) ... (IMG:style_emoticons/default/unsure.gif)
I need some TB's for my Jenvey, Extrudabody and TWM TB's are crazy frickin' expensive for what they are, so I'm going the Motorcycle TB route. This is what came in the mail today, stuff looks real good (IMG:style_emoticons/default/piratenanner.gif) Attached image(s) |
kevin311 |
May 10 2013, 07:07 PM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
What size engine are these going on? What are the throat sizes on them? What are you using to control them? I'm doing something similar with VFR800 ITBs. I really like how those come apart. The VFRs are 2 two-barrel castings. I'll be following this one. (IMG:style_emoticons/default/aktion035.gif) 1.7 with VFR800 tbs (work in progress) http://www.914world.com/bbs2/index.php?showtopic=192548 |
Phoenix-MN |
May 10 2013, 08:14 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
What size engine are these going on? What are the throat sizes on them? What are you using to control them? I'm doing something similar with VFR800 ITBs. I really like how those come apart. The VFRs are 2 two-barrel castings. I'll be following this one. (IMG:style_emoticons/default/aktion035.gif) 1.7 with VFR800 tbs (work in progress) http://www.914world.com/bbs2/index.php?showtopic=192548 Mine are going on a 2.5L six and I'm using a Holley HP EFI ecu with crank fired ignition. The throat size on the GSX R600's is 38mm. My carbs are currently using 32mm venturies so 38's should be in the ball park. |
Lo-Fi Version | Time is now: 26th May 2024 - 05:57 PM |
