My turn at motorcycle Throttle bodies, making progress |
Mark Henry |
May 10 2013, 10:57 AM
Like I need another project... Beginning to be as bad as Dr Evil (IMG:style_emoticons/default/laugh.gif) ... (IMG:style_emoticons/default/huh.gif) ... (IMG:style_emoticons/default/unsure.gif)
I need some TB's for my Jenvey, Extrudabody and TWM TB's are crazy frickin' expensive for what they are, so I'm going the Motorcycle TB route. This is what came in the mail today, stuff looks real good (IMG:style_emoticons/default/piratenanner.gif) Attached image(s) |
Mark Henry |
May 15 2014, 10:52 AM
Everything on this build is custom, between the engine and the car I'm betting 1500 hours.
Your friend is either going to bail on you, hate you or start charging you money. I'm guessing, but I have at least 120 hours in the TB's alone. I didn't make templates. At first things went fast enough that I thought about making and selling a few sets, but I |
Moneypit |
May 15 2014, 11:41 AM
Member Group: Members Posts: 195 Joined: 4-January 06 From: Georgetown, TX Member No.: 5,360 Region Association: Southwest Region |
Everything on this build is custom, between the engine and the car I'm betting 1500 hours. Your friend is either going to bail on you, hate you or start charging you money. I'm guessing, but I have at least 120 hours in the TB's alone. I didn't make templates. At first things went fast enough that I thought about making and selling a few sets, but I If anything my Friend would show me how to do things, not just do all the work. If I discover things deeply out of my pay grade I'd pay him. That, and there's a pretty solid welding/fabbing/machining presence up in this area. If I gan get back into 3d design stuff like CAD (used to use 3DS Max for game models), maybe someone can print them out on a 3d printer. If everything mates properly, then CNC out of aluminum? (IMG:style_emoticons/default/confused24.gif) I figure this all would involve a lot of machining, especially in trying to get the TBs to align with and mate to the intakes, and especially getting the linkages sorted out! Then of course there's the fuel rails that would need to be correct for the TB's spacing, am I right? I see the issue of having to fab everything up. In terms of the linkages, is it extremely complicated getting each pair of TBs slaved to each other? I was trying to think if you could rig up a system similar to Tangerine's pulley/slave style and have a TPS on the "master" TB? |
Mark Henry |
May 15 2014, 03:01 PM
Everything on this build is custom, between the engine and the car I'm betting 1500 hours. Your friend is either going to bail on you, hate you or start charging you money. I'm guessing, but I have at least 120 hours in the TB's alone. I didn't make templates. At first things went fast enough that I thought about making and selling a few sets, but I If anything my Friend would show me how to do things, not just do all the work. If I discover things deeply out of my pay grade I'd pay him. That, and there's a pretty solid welding/fabbing/machining presence up in this area. If I gan get back into 3d design stuff like CAD (used to use 3DS Max for game models), maybe someone can print them out on a 3d printer. If everything mates properly, then CNC out of aluminum? (IMG:style_emoticons/default/confused24.gif) I figure this all would involve a lot of machining, especially in trying to get the TBs to align with and mate to the intakes, and especially getting the linkages sorted out! Then of course there's the fuel rails that would need to be correct for the TB's spacing, am I right? I see the issue of having to fab everything up. In terms of the linkages, is it extremely complicated getting each pair of TBs slaved to each other? I was trying to think if you could rig up a system similar to Tangerine's pulley/slave style and have a TPS on the "master" TB? If you're paying just go for the Weber Or CB TB's, they are a bolt on. Basically I made everything, saved me a boatload of coin, but that's not counting the time. $80 for the TB's (ebay), the manifolds were free, $48 for the linkage ends (FLAPs) and $50 for the air filter assemblies (cip1) and $50 for the injectors (ebay). Say about $100 for FI hose, clamps and fittings, etc. Pump is from a VW van, the oil filled pump pressure gauge cost me $15 Most of the rest I had kicking around (just taking about the intake here). I bought the SDS almost 10 years ago it had the TPS, MAP, etc. The O2 meter is about 6 years old I've used it on many cars. |
Lo-Fi Version | Time is now: 26th May 2024 - 02:18 AM |
