My turn at motorcycle Throttle bodies, making progress |
Mark Henry |
May 10 2013, 10:57 AM
Like I need another project... Beginning to be as bad as Dr Evil (IMG:style_emoticons/default/laugh.gif) ... (IMG:style_emoticons/default/huh.gif) ... (IMG:style_emoticons/default/unsure.gif)
I need some TB's for my Jenvey, Extrudabody and TWM TB's are crazy frickin' expensive for what they are, so I'm going the Motorcycle TB route. This is what came in the mail today, stuff looks real good (IMG:style_emoticons/default/piratenanner.gif) Attached image(s) |
Mark Henry |
May 10 2013, 11:01 AM
Damn... you think they would get the spacing correct (IMG:style_emoticons/default/mad.gif)
80mm center to center spacing..... (IMG:style_emoticons/default/sad.gif) I need 90mm.... Attached image(s) |
Mark Henry |
May 10 2013, 11:07 AM
The bike injectors are shorter and I don't know if the fuel rails have enough meat to be cut an tapped for pipe threads.
The seals area bit different as well but think it's workable. The bike injectors are only 22lbs the black injectors are 50lbs Attached image(s) |
Mark Henry |
May 10 2013, 11:09 AM
Take them all apart and i have 4 separate ITB's (IMG:style_emoticons/default/shades.gif)
Attached image(s) |
Mark Henry |
May 10 2013, 11:13 AM
Going to take a bit of (IMG:style_emoticons/default/smash.gif) but I'm thinking these are going to work out beauty. (IMG:style_emoticons/default/smile.gif)
Mark Henry |
May 10 2013, 11:24 AM
Going to take me a little bit to get going on this, my 914 is also getting a 3.0 /6 at the same time, so I'm bleeding money....but I try to update as do.
Debating on should I make adaptors or just machine the CB manifolds and JB weld the TB's in place. The JB weld method would save a lot of fab time. I also should match port the funky bottoms on those TB's. |
SirAndy |
May 10 2013, 11:35 AM
Resident German Group: Admin Posts: 41,614 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Debating on You should get a set of these: (IMG:http://www.914world.com/bbs2/uploads/post-11-1124689756.jpg) That way, you can run the big injectors where they should be, close to the intake valve, and use the TBs to regulate the air. (IMG:style_emoticons/default/shades.gif) |
Mark Henry |
May 10 2013, 11:41 AM
Debating on You should get a set of these: (IMG:http://www.914world.com/bbs2/uploads/post-11-1124689756.jpg) That way, you can run the big injectors where they should be, close to the intake valve, and use the TBs to regulate the air. (IMG:style_emoticons/default/shades.gif) You want to sell those? (IMG:style_emoticons/default/biggrin.gif) Maybe... I will but for now I think I'll just take the simple route. I'm trying to shake off the DWD and get my projects done. I can fine tune the details each winter after that. (IMG:style_emoticons/default/smile.gif) |
worn |
May 10 2013, 11:43 AM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Randal |
May 10 2013, 12:18 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Mike Mueller was messing with bike TB's years ago. He went through the whole process which can be see on the link below. I, on the other hand I ended up going the TWM route as their TB fit a Weber type manifold and I had way to many "projects" on my engine.
You can probably contact Mike somewhere on this site or the club site. OK found the link: http://www.914world.com/bbs2/index.php?sho...torcycle+TB%27s |
Mark Henry |
May 10 2013, 12:27 PM
Like I need another project... Beginning to be as bad as Dr Evil What did the TBs come off of? I have pondered this for my TR6. Well I have at least 40hrs and this is my 3rd set of TB's into the research on this, so I'm not going to tell you what exact make and model. Google is your friend and the truth is out there. Looking like I might also build a few sets this winter to sell ...maybe...if I don't I'll tell all...sneak peek (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
Dr Evil |
May 10 2013, 02:32 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
This is a project I want to do in the future as well (IMG:style_emoticons/default/biggrin.gif)
bulitt |
May 10 2013, 02:44 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Going to take me a little bit to get going on this, my 914 is also getting a 3.0 /6 at the same time, so I'm bleeding money....but I try to update as do. Debating on should I make adaptors or just machine the CB manifolds and JB weld the TB's in place. The JB weld method would save a lot of fab time. I also should match port the funky bottoms on those TB's. Maybe you should just bore the manifolds so the TB recess in the bores, then drill and tap for two hold down screws/tabs for each TB. Looks like there is a recess for o-ring around base of each TB ? |
Dr Evil |
May 10 2013, 02:47 PM
Or mill of the flange of the manifolds and use a rubber coupler like the bikes do (IMG:style_emoticons/default/smile.gif)
Phoenix-MN |
May 10 2013, 03:53 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Or mill of the flange of the manifolds and use a rubber coupler like the bikes do (IMG:style_emoticons/default/smile.gif) Boy, EFI ITB's is like a sickness. I started my project for my "Tail Dragger" a month or so ago with Suzuki GSX R600 ITB's. Lot's of threads on the Bird Board. I used the stock rubber couplers and redrilled the mounting holes on the manifolds. |
rick 918-S |
May 10 2013, 05:05 PM
Hey nice rack! -Celette Group: Members Posts: 20,441 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Lots of chatter about ITB's. I'm researching a fuel management that you can apply instead of building on from scratch. I'm hoping to find something to tweek. Why reinvent the wheel. Lots of cars and bikes are running injection. Just take something that the OEM developed and is currently in use and tune it.
Randal |
May 10 2013, 05:06 PM
Or mill of the flange of the manifolds and use a rubber coupler like the bikes do (IMG:style_emoticons/default/smile.gif) Mike Mueller actually did this. Check out the link in my post. |
kevin311 |
May 10 2013, 07:07 PM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
What size engine are these going on? What are the throat sizes on them? What are you using to control them? I'm doing something similar with VFR800 ITBs. I really like how those come apart. The VFRs are 2 two-barrel castings. I'll be following this one. (IMG:style_emoticons/default/aktion035.gif) 1.7 with VFR800 tbs (work in progress) http://www.914world.com/bbs2/index.php?showtopic=192548 |
Elliot Cannon |
May 10 2013, 07:09 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
What will be used to trigger the injectors?
Mike Bellis |
May 10 2013, 07:21 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Lo-Fi Version | Time is now: 4th May 2024 - 06:53 AM |
